07-02-2011, 08:29 AM   #151
Blue's Avatar
QuoteOriginally posted by Emacs Quote
I tried NX 20 and 30 a couple of times. You can find the NX 30 test here: Samsung NX 30mm f/2 - Review / Test Report - Analysis
And these are DA 35Ltd, DA 35 and FA 35:
Pentax SMC DA 35mm f/2.8 Limited macro - Review / Test Report - Analysis
Pentax SMC DA 35mm f/2.4 AL - Review / Lens Test - Analysis
Pentax SMC-FA 35mm f/2 AL - Review / Test Report - Sample Images & Verdict
Samsung: 4 stars and good resolution figures at the cost of DA 35
DA35Ltd: 3.5 stars and the worst resolution, and THE COST. Macro freaks can love it though.
DA35: 3.5 to 4 stars, slightly worse resolution than one of samsung
FA35: 4 stars, the same resolution with samsung, it heavier and larger though. The cost is twice higher.
I couldn't find any proper NX 20 testing in the web. But since I tried the DA 21Ltd, and have CZ Distagon 21, I can make evaluations I suppose.
So, my opinion is the NX 20 is very good. Definitely better than 21Ltd. Not as good as Distagon, but the difference between them is less than one between NX 20 and 21Ltd. But (NX20 + 30f2) Kit + 20f2.8 + 16f2.4 in will cost less than one Distagon, and the weight would be only slight more than one of Distagon (400g + 90g + 90g + 90g)! And it would be lighter and smaller than K-5 + DA 35 + DA21Ltd + DA15Ltd. And the IQ will be better: 18mp sensor with more DR, about the same high ISO performance combined with better lenses.
So I don't really see a point why newcomers should buy Pentax with tons of quality issues if they don't have bunch of FA stars and limiteds.
#1: You are comparing across systems plus a 14.6 mp sensor with a 10 mp sensor.
#2: The NX does distortion control on the lenses in the body like the m4/3 system does.
#3: The star rating has nothing to do with the actual numerical data in the tests.
#4: Photozone isn't the most Pentax friendly site given they often give a thumbs up to Nikon or Canon gear that performs at a lower level than similar gear by other brands including Pentax.
Samsung NX 30 mm f/2.0 review - Distortion - Lenstip.com
Nothing wrong with the system for what it is but it isn't a dSLR.
07-02-2011, 08:35 AM   #152
And your point is?
:sarcasm:
Oh, that sarcasm tag is awesome! I've never seen that before! ROFLMAO!
07-02-2011, 08:50 AM   #153
Those links don't say what you're suggeting they do. The Samsung starts out very good and makes it to excellent. The FA35 starts out good with better edge-to-edge performance, and goes to outstanding, with much higher edge-to-edge resolution. The DAL is better from the start. What you're claiming *might* be true of the DA35ltd - I had one, and it's not nearly as sharp as the FA35f2. Regardless, as photozone.de REPEATEDLY cautions, you can't use the evaluations for comparison between different sensors.
You're entitled to your opinions. I only challenge you because you present them as though they're facts - and so far the information you've provided doesn't support your claims. Even if we translate the numbers directly between sensors, which photozone repeatedly says you shouldn't do.
07-02-2011, 01:23 PM   #154
Ash
Community Manager
Ash's Avatar
I don't see any point to buy Pentax DA pancakes nowdays, this market is over for DSLRs
Seems you're just sold out on the EVIL system.
Just as there is a benefit in FF over APS-C, there is considerable benefit of Pentax APS-C over the Q or the NX or whatever EVILs there are around; in more ways than one. You can justify it all you like yourself, but that doesn't change dSLR's utility amidst this new technology. It's fine to have a personal preference, but if you keep asserting how much the NX system is superior over Pentax APS-C, you might find your credibility starting to flake...
DA 35 ltd, the worst? In what? Criticising a higher-end macro over a consumer non-macro of the same focal length in this way is like disparaging a heavy-duty 4WD vehicle for not having as smooth a ride as a Toyota Camry.
07-02-2011, 02:16 PM   #155
Aristophanes's Avatar
QuoteOriginally posted by RBellavance Quote
Agreed, although I'd tone it down to "a niche future".
The big money niche.
There is a robust MF market with no less than 6 suppliers and bodies selling for $20,000.
Porsche is a niche. I'd rather have one than a Camry.
07-02-2011, 03:37 PM   #156
yeatzee's Avatar
and the ever stupid decision to build 85 f1.4 for APS-C system, they better introduced some kind of 50 f1.X/55 f1.X
Am I the only one that LOVES 85mm on APSC? I'd have no choice but to purchase a fast 135mm if I shot FF.
07-03-2011, 12:50 PM   #157
Didn't you get the point Samsung NX lenses are superior to Pentax DA analogues both optically and by weight? The NX 2* will likely have better sensor than even K-5. And this will cost twice cheaper than K-5. What's the point then in buying Pentax? Only larger sensor will make Pentax a good choice.
any sensor that si newer will be better than the older sensor, so your point is?
07-04-2011, 12:48 AM   #158
Someone should kick off 15 years old troll :ugh:
07-04-2011, 03:50 AM   #159
Samsung is clearly way behind Sony when it comes to sensor development. I am sure they are coming up something to answer Sony's newest 16 megapixel sensor, but the reality is the Sony is working on the next generation that will pass that up. For whatever reason, Samsung hasn't been able to do any better than the sensor that was in the K20/K7. Its sad really...
07-04-2011, 04:18 AM   #160
TaoMaas's Avatar
QuoteOriginally posted by yeatzee Quote
No, you're not.
07-04-2011, 06:29 AM   #161
RioRico's Avatar
Yes, it's just you.
Nobody else wants 85mm lenses.
All those high 85mm prices are just a conspiracy.
07-04-2011, 07:24 AM   #162
RonHendriks1966's Avatar
No you are not. I have DA*55mm/f1.4 and FA*85mm/f1.4 and I would like to these two a DA*135mm/f2.0 to complete this magnificent lensline of portraitlenses.
07-04-2011, 06:16 PM   #163
Blue's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
Are you sure you wouldn't prefer a DA L 135/4 to complete your line? (without a hood to keep the price down)
07-04-2011, 06:17 PM   #164
Blue's Avatar
Yes, it's just you.
The conspiracy runs so deep that I have been making do with an FA 77 ltd.
07-04-2011, 08:40 PM   #165
paperbag846's Avatar
QuoteOriginally posted by GeneV Quote
An interesting point. We've seen more new in cropped sensors lately. I wonder if Nikon is finding the market for a 2.5 lb body than costs $3-5k may not be as huge as expected.
This is why I would never buy a FF camera even if it was 500 dollars. I want a small tool, I value compactness.
camera, dslr, films, image, lenses, passion, pentax, photography, production, slr, switch
How do the K5 photos compare to Full Frame camera photos as far as the "look" goes? crossover37 Pentax K-5 166 05-16-2011 07:24 PM
Full frame or improved AF. What do you want in the "K-8"? johnmflores Pentax DSLR Discussion 73 06-04-2010 11:35 AM
Nikon's 1998 vintage "full frame" DSLR pingflood General Talk 5 07-25-2009 05:44 PM
How does the camera "know" where the first frame starts? pbo Pentax Medium Format 9 07-08-2009 08:23 AM
German c't calls K-7 "full frame" falconeye Pentax News and Rumors 3 05-24-2009 11:18 PM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, part of our network of photo forums!
