Originally posted by rawr The OP's post illustrates the virtues, however, of not playing with the debug menu unless you really know what you are doing, and what the consequences may be.
What he said....
Sometimes it is very difficult to determine exact point of focus - there is some inconsistency - I hasten to add it is probably mostly the user.
Bearing this in mind - probably should not be too hasty in making any adjustments in the focus department.
The trouble is - once we have something like the debug menu - there is a real tendency to want to fiddle - to see if we cannot get "even better" performance.
The factory has equipment to do the adjustments with some precision, and it is hard to improve on this by sight only -
so only if a focusing error is detected with some consistency that this kind of an adjustment should be made.
Just to throw in another possible complication - different lighting can make a difference - especially artificial light, attempting "critical" adjustments under the wrong lighting conditions can throw off the focus for other more normal lighting conditions.
