And I have some questions on how to improve image quality.
It was cloudy and pretty crappy out this morning when I was shooting. I thought, though, that I'd be able to work around it.
Let's preface the entire conversation by saying up front that I know next to nothing about photography, but I've read some of the "Ultimate Exposure Computer" and I do understand the relationship between ISO, Aperture, and Lens Speed, so I have the basics figured out.
I think I made a mistake by biting off too much and setting the k10 in manual mode, and setting my ISO at 200. I just arbitrarily chose that value, maybe it was a bad idea in the lighting conditions I was under. If I had a do-over I'd have set it to TAv just to simplify things on myself.
With that said, it seemed like the biggest problem I faced was an issue of contrast? (I'm not sure if it really is contrast), where I would lose detail (all detail) at the tops of trees against the greyish bright sky. Here is an example photo to show you what I mean, first of the scaled down full scene, then with a 100% crop of the treeline.
(EDIT: They're now attached and should show up at the bottom of the post... I tried to link to them from another website, and apparently that didn't work, even though I could see them on my screen (?)... thanks for the heads up Peter Zack)
Here's the information from the Pentax Photo Viewer for my camera settings:
(Is there a way to copy paste this stuff? I can't seem to figure out how to...)
Lens: Kit lens
Focal Length 28.0mm
Shutter speed: 1/125sec
Aperture: F5.6
Capture mode: Manual
Metering: Multi-segment
White balance: Neutral white fluorescent (I know this wasn't helping... I had accidentally left it on this setting from shooting indoors last night)
Sensitivity: 200
Any ideas on what could be done to fix this sort of situation?
I tried adjusting the Aperture and Shutter Speed, went up and down in both directions and didn't seem to have much luck with that. Did I need to adjust the ISO? Did I need to adjust the metering? The White balance?
I'm going to encounter a lot of shots like this- I love nature and horizon shots contrasting sky and trees- so I would like to figure out how to get these right.
Any information is most appreciated! Thank you!!!
(Oh, and I did get some shots right- I can do the close up stuff pretty well, and I love playing with depth of field!!)
Best Regards,
-Tim
Reason: Trying to get images to appear
