Originally posted by Larsenio I`m afraid you`re misunderstanding... 1:1 view is 1:1.
No, I know 1:1 is 1:1. But the image from the k20d is magnified more
at 1:1. Because the k10d is 3872 pixels across, and the K20D is 4672 pixels, the image on your screen is a smaller piece of the sensor; that is, higher magnification.
Perhaps you're seeing the resolution limits of your lenses, or some change in the process workflow. I assure you the K20D doesn't typically have noticeably more aliasing ("stair stepping") than the K10D, and I routinely got single-pixel level resolution out of the K20D combined with several lenses.
If you're using lightroom, try this: Pick your images that you're comparing at 1:1, export them both to, say, fit into 1200x1200 pixels, sharpened for screen display. Then compare them at 1:1. Or scale them both to, say, 20MP and compare them.
Or, even better, take the images in question and get an 8x10 of each, and THEN compare them.
