07-13-2011, 09:26 PM   #1
K-x disassembled?
Has anyone ever had the guts to break down a K-x on to its bear electronics? What is inside, i am very curious. i am really into a grip for the k-x is it possible to wire a micro connector to the switch? And the mic do you think its able to fit one more connector in the body of the camera?
07-14-2011, 05:07 AM   #2
aurele's Avatar
maybe it could be done, but make no mistake : all the room avaible is use; So you'll have to have it outside of the body.
07-14-2011, 03:58 PM   #3
wire the connectors outside?
07-15-2011, 07:15 AM   #4
Shutter switch?
https://www.pentaxforums.com/forums/members/gp1806-albums-k200d-repair-picture23528.html
07-15-2011, 03:14 PM   #5
looks like i am able to solder wires to that switch.
07-15-2011, 03:36 PM   #6
Thanks Gp1806!
07-15-2011, 06:30 PM   #7
If you want to try this, when taking the top of the camera off, there is a screw in the battery compartment that is hard to see, and there are screws under the pop up flash too.
07-15-2011, 06:33 PM   #8
I have a K10D approaching 'in pieces' levels... Its very very *very* cramped in there (and the K10 has bigger body than Kx no? Admitedly the K10D has more circuitry for the Li-Ion batteries etc.. but not that much more... ).. I also will be happy to never see a single flexible PCB again.. the things covered in them.. so you'll need a very fine tipped iron with reliable tempreature controls
Check out the pentax service manual on Downloads - it at least will give you an idea of the component groups.
07-15-2011, 06:47 PM   #9
that is true. and i was thinking of leading the wires out of the body threw the battery compartment. and lead it into a grip of a sort.
07-20-2011, 03:32 PM   #10
kh1234567890's Avatar
https://www.pentaxforums.com/forums/pentax-dslr-discussion/119619-dismantling-k100d.html
07-20-2011, 07:09 PM   #11
GerryL's Avatar
QuoteOriginally posted by kh1234567890 Quote
K100D stripdown
Doesn't take you where you are supposed to go.
07-22-2011, 04:39 PM   #12
im just trying to accesses the mic and wire them outside. by soldering wire in parallel to the contacts. also and trying to wire out the trigger button for an external grip. also if possible remove the grip and make a custom paint color =D
camera, connector, dslr, k-x, photography
Anyone disassembled 70-300mm Sigma? tr13 Pentax SLR Lens Discussion 0 09-09-2009 12:57 AM
All times are GMT -7. The time now is 06:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
