With my K-X I'm puzzled by an interaction between the aperture I select and the focus distance that autofocus picks (in Av mode). I see this especially with an ultrawide lens (Tamron 10-24 at the 10mm end, less so at 20mm+), and less noticeably with wide angle (Sigma 17-70 at the 17mm). Here’s what happens, using spot autofocus and the same targets at distances of 50 yards to 1000 yards (a large target (bridge) in the latter case), with no intervening objects for the AF to focus on:
At (for example) f3.5, the autofocus stops with the focus ring at a particular place—about at the 7 foot mark on the focus ring in the case of a far away subject. It stays at the exact same focus point if I change aperture to, say, 4.0 or 5.6. But if I change the aperture to 8.0, the autofocus shifts the dial to the infinity mark. I thought that AF always takes place wide open, so I don’t understand why, when moving to f8, it would suddenly recalculate and select a new, noticeably different focus ring position. If the autofocus uses the lens wide open, why would it consistently shift to a different result when I change aperture to f8? The same thing happens, but to a lesser degree, at longer focal lengths, and with the Sigma at the 17mm end, though at longer focal lengths the focus ring shifting takes place at about f11 (and is in the other direction on the Sigma—it goes from having selected a longer distance to a slightly shorter distance when I change aperture to f11).
Normally I’d attribute this to sloppiness in the Tamron and Sigma quality control. But the fact that it happens predictably (always at f8 on the Tamron) suggests not sloppiness, but something about the way the choice of aperture influences the way autofocus calculates its stopping point with wider angle lenses. (For example: does the smaller aperture setting actively tell autofocus that it’s got more depth of field to work with, leading to a different choice of focus point, with the transition to f8 being the trigger for this?) I’m puzzled as to whether this is supposed to happen or not, as it does affect exactly where in the overall depth of field the best focus occurs. Thanks much for any insight.
Reason: clarify question to avoid confusion with the 11 autofocus points
