11-23-2007, 07:14 PM   #1
Memory Card Speed Advantage?
Will the k100d, or the k100d super take advantage of a faster memory card? I thought I saw a posting somewhere that said it didn't matter. There are a lot of sales on medium speed chips, but I would hold out for a faster chip if it made a difference, particularly in the time it takes to upload to the computer.
11-23-2007, 09:32 PM   #2
smokey's Avatar
Recently with my K10D, I was shooting in continuous mode with a Lexar 4GB SDHC Platinum II 60x. No problem. When I filled that, I changed to a Lexar 1GB (unknown speed, but think it is 20x maybe?). Noticed a big slowdown in writing to the card.
Originally, I thought it only made a difference when copying to and from the computer, but it does make a difference in write speed from the camera.
11-23-2007, 10:10 PM   #3
mattdm's Avatar
From what I've seen, the K10D can write at the approximate equivalent of 66. So, you'll see an improvement going up to that speed but not much of a win beyond it.
The K100D is somewhat slower innately, but you'll still definitely notice the effect of using a really slow card.
11-23-2007, 10:48 PM   #4
Ash
Community Manager
Ash's Avatar
I'd looked into this before, and found the K100D to have a decent cache, good enough to take 3 RAW pictures in quick succession, but then it takes about 5 sec. to offload one of those pictures (10Mb), regardless of my memory card speed.
I have Toshiba 4Mb/sec and 6Mb/sec cards, with similar results - max write speed of about 2Mb/sec, limited by the K100D, not the memory card. So unless your memory card's write speed is slower than 2Mb/sec, it doesn't matter which one you choose in the K100D.
11-23-2007, 11:05 PM   #5
however, having a faster card can make a difference getting images onto your computer. Much less time.
11-24-2007, 10:47 AM   #6
Finn's Avatar
I use a 2GB regular Sandisk card and a 1GB Extreme III card on my K100 and I have noticed ZERO difference in speed between the two. I haven't noticed a lot of difference loading onto the computer, but I really haven't paid much attention to that. If you have a K100, save your money and buy a larger capacity "regular" SD card.
camera, card, dslr, k100d, memory, memory card, photography
*ist DS "memory card error" - card won't format WMBP Pentax DSLR Discussion 6 04-05-2016 04:39 PM
Memory card "card not formatted" error mickc Pentax Camera and Field Accessories 7 07-12-2011 08:49 PM
Will Class 10 memory card help with preview speed (K-7)? skyredoubt Pentax DSLR Discussion 3 10-18-2010 07:14 PM
memory card speed jani Photographic Technique 2 06-01-2008 02:23 PM
K100D Super memory card speed Antitrust Pentax DSLR Discussion 3 09-10-2007 09:32 AM
All times are GMT -7. The time now is 03:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
