11-25-2007, 05:47 AM   #16
baw
Filenaming.
QuoteOriginally posted by davek Quote
I just started running into this problem since I got my K10D.
Right now, I'm trying a new file rename technique to see how it fits in my workflow.
Upon conversion from raw, I'm creating the filename based on the Exif shooting date data: yyyymmddd-hhmmss.jpg
This will automaticaly sort my images regardless of camera in chronological order.
The 2 risks I see with this are:
1) 2 pics taken at the same time (different shooters?) will have the same name. I figure the risk of this is low.
2) The converted file is no longer the same as the raw file. This may make correlating the 2 more difficult. Not certain how much that'll impact me yet.
I leave the original camera number as part of the file name (nostalgia?)
I don't use seconds, too difficult to read, and not necessary imo.
So filenames are: yyyymmdd_hhmm_####.ext
Also covers burstmode shooting. (one camera, multiple images in same second.)
Only risk on double filenames is different cameras having the same counter# in the same minute.
11-25-2007, 01:49 PM   #17
QuoteOriginally posted by simonm Quote
Thus the original file is only opened once and saved unmodified; there's a copy at 'high res' and a copy at 'low res'.
Simon
Hi Simon,
I noted your "saved unmodified". I assume that you actual closed it after saving as a new name or closed it without saving. If you save over your original you have made a change to it.
David
11-26-2007, 12:02 AM   #18
Canada_Rockies's Avatar
My K10D is set to group shots by date in the custom settings, so my file names are in directories such as 100-1118 on the card in the camera. The 1118 is November 18th. No year, but the year is in the EXIF data, and I download by year anyway. All my original images copied from the camera are now in as an example, on my Windows ThinkPad:
My Pictures > 2007 > 100-1118
My Pictures > 2007 > 100-1120 (didn't shoot on the 19th)
My Pictures > 2007 > 100-1121
and so forth.
I have USER set to PEF + JPEG
When 2007 is over, I will move all off onto a couple of USB drives as a backup, and also write a DVD with all the images. That will work this year - next I will probably need more than one DVD.
11-26-2007, 10:07 AM   #19
QuoteOriginally posted by baw Quote
Thanks, I like that idea better, as it leaves the original filename imbedded, if I need to dig out the Raw file source again.
03-05-2008, 03:05 PM   #20
I too have recently added a K100D super --- previously used a *istD
My first few images were numbered as IMGP####
I had tried out my sons K100D to se how good it was. I used my own card.
After inserting that card into my K100D super it swapped its file numbering to _IGP#### which what was on my sons camera.
Didn't shoot raw in either camera.
This is OK as I now have different file numbering systems from each camera but how it did this I still don't quite understand.
The manual is a little vague on this point but if I read it correctly, whilst it is a "virgin" it seems to adopt what it finds on a card and follows on from that.
Problem is how to turn it back to a "virgin" as it doesn't have a backup battery as the *istD does.
Any comments from anyone??
03-05-2008, 03:22 PM   #21
Lowell Goudge's Avatar
QuoteOriginally posted by hamdala Quote
what you have is one camera set to adobe color space and the other to RGB.
You probally really want them both to adobe color space.
this will be _IGPXXXX.
as I understand it the K20 allows for different file names
03-05-2008, 04:10 PM   #22
Thanks Lowell
Case of RTFM
This gives me a rather neat solution to conflicting file names since the *istD churns out IMGP#### regardless of colour space
I like to shoot using adobe and have both cameras set to this.
Maybe a possible solution for Simon???
03-05-2008, 04:29 PM   #23
Thanks Lowell
Case of RTFM
That;s interesting, mine doesn't!
might be a software issue on yours, mine is on latest version which supports 4GB cards
03-05-2008, 05:27 PM   #24
I use ckrename for my files. Free and very simple to use.
I have 6 dslr's and need to rename a lot when file names start to over lap
Dave
03-05-2008, 07:34 PM   #25
Yes Lowell,
I think you are probably right. I still have an early software version - updates didn't give me anything I needed.
03-05-2008, 08:34 PM   #26
I always store my pics according to date, then by the event, that way I can sort the folders by when they took place. For example:
2007_12_31 new years party
or
2008_02_22 bob's birthday bash
I keep things simple by using as few subfolders (within the 'My Pictures' folder) as possible, like:
Family & Friends Events
Cars
Vacations
Random
03-06-2008, 05:42 AM   #27
QuoteOriginally posted by arthur pappas Quote
or
Cars
Vacations
Random
That all works just fine except....
the counter in my *istD and K10D are extremely close, and I shoot both during the same event, this will make for the extreme possibility of conflicting file names within the folder.
I don't want to reset either counter, therefore I will have this problem moving forward. the same issue exists for pro's who shoot multiple bodies. I should not have to deal with this issue, either when downloading or later.
camera, card, dslr, file, files, ist*d, k100d, photography, sequence
KX File numbering mess up GaryH Pentax DSLR Discussion 10 09-10-2010 07:04 AM
Pentax K-x Image File numbering avsroy Troubleshooting and Beginner Help 9 03-23-2010 12:45 PM
File numbering greenjewel Pentax DSLR Discussion 5 11-09-2009 01:18 PM
File numbering question MSM Troubleshooting and Beginner Help 2 06-25-2009 08:32 PM
Resetting File Numbering Mikhail Pentax DSLR Discussion 1 10-19-2007 01:15 PM
All times are GMT -7. The time now is 10:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
