08-01-2011, 08:16 AM   #1
Dirty in Viewfinder
Hi, I have a k-x and its viewfinder has several black dots when I see through to get focus. I blew the focus screen, mirror and sensor already, even I used soft brush on the focus screen and mirrors. The dots still here and same location. My question is how to remove the dots out. Thanks.
08-01-2011, 08:44 AM   #2
Marc Sabatella's Avatar
You'd have to remove the focus screen. Search the forum for the existing threads on the topic, and then decide if it's worth the risk. In general, most people just learn to live with the spots that inevitably come and go.
08-01-2011, 09:09 AM   #3
Risk? There is no risk in removing a focus screen. If there is, you are either extremely unlucky or extremely clumsy. But first make sure where the dirt is located. Could be either viewfinder, focus screen or mirror.
08-01-2011, 01:17 PM   #4
Let's say the dots are in viewfinder, how can i clean it? it's really look like the dots stuck in VF.
08-01-2011, 01:41 PM   #5
QuoteOriginally posted by Kenneth3aracing Quote
Try blowing on the focus screen with canned air, without removing the focus screen first. Rocket Blower or it's equivalent works, just not as well because squeezing the bulb can change the nozzle positioning too much to be as effective as canned air. If this doesn't remove the debris from the focus screen, remove the screen from the camera and blow on it outside of the camera. If all this doesn't do the job, you can wash the focus screen under warm water with soap, rubbing it with your fingers to dislodge any stubborn debris. Let the screen dry thoroughly, visually inspect the screen and reinstall in camera when you are satisfied of the screen's cleanliness.
Thanks,
08-01-2011, 02:56 PM   #6
Had the same problem.
Sloution found via link here
08-02-2011, 09:29 PM   #7
QuoteOriginally posted by Skog Quote
I'm not saying you might electrocute yourself or anything, but do a search and you'll find many references to people scratching their focus screen, getting fingerprints on it, not being able to get the shim back in properly and thus ending up with inaccueate focus, and/or ending up with more dirt on the screen than they started.
camera, dots, dslr, focus, photography, screen, viewfinder
Dirty/noisy Viewfinder volthord Troubleshooting and Beginner Help 4 03-05-2011 04:38 AM
What's dirty? Javaslinger Troubleshooting and Beginner Help 17 07-19-2010 11:48 AM
Dirty Viewfinder Scott_the_Artist Troubleshooting and Beginner Help 8 08-14-2009 10:26 PM
Dirty viewfinder kent Troubleshooting and Beginner Help 10 07-18-2009 12:18 AM
Dirty viewfinder problem? blank Pentax DSLR Discussion 6 01-13-2009 01:42 PM
All times are GMT -7. The time now is 07:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
