Originally posted by Emacs The first aspect you can close aperture a bit but get the same DOF as on APS-C and achieve more contrast and sharpness.
Thank you for responding with specific details. I admit you are correct here but the same goes for even larger sensors. Shooting medium format one can pretty well forget about obsessing over lenses because
they all look good. And proper photographic technique matters so much more anyway.
For what it's worth I get plenty of contrast wide open (on APS-C) and can coax so much out of the RAW files it's just silly. This is one of those theoretical differences that makes no difference to real photography. (I would not say this about a lot of cruddier older lenses, but we are talking FA Limiteds here.)
Originally posted by Emacs The second aspect lenses wide open are more usable on FF than on APS-C because 1.5 «magnification» on the latter makes halos (and other aberrations) more visible. The typical examples are 31Ltd and A 50 f1.2 which look soft wide open on APS-C, but they are quite sharp on FF at f1.8 and f1.2 respectively.
Do you have some comparison photos? Certainly the 50/1.2 is soft and aberration-filled wide open, but I have seen the same with film shots. (Isn't that why people use it? For "character"?) I don't have the FA31 but the FA43 is decent wide open despite the test figures that show very poor sharpness at the borders. All depends on how you use it. (I have a thread demonstrating this somewhere on this forum.)
A far more valid criticism is that the FA77 (worst offender of the three) fringes horribly on specular subjects. But all this means is that our lenses aren't perfect and we have to work with them. I don't think a 35mm sensor is a cure-all. But I await correction by way of solid and consistent photographic evidence. In the meantime I offer up the FA Limited thread on this very forum as ample evidence that a half-way decent photographer in no way needs a 35mm sensor to make lovely photos.
In the meantime I will stop posting since I am likely giving the impression a larger sensor would be a bad idea. Whereas in truth I believe the larger the sensor the better! I simply refuse to see 35mm as a magic wand. And on the pragmatic side, I can't imagine a company that makes disposable money-grab items like the GXR and Q caring to go that route.
