Originally posted by Eruditass I don't recall: does the K10D's bulb mode allow one click to open the shutter and one click to close it? Can you access bulb mode from manual mode or does it have to be set to "B"?
I sold my K10D a while back, but if I recall correctly, the K10D's bulb mode does not allow one click to open, one click to close; i.e. you have to hold down the shutter button (I used to use an corded remote shutter release that had a lock button, and that worked).
Originally posted by Eruditass Can you select bulb mode in manual or must you be in "B" mode?
No, the K10D must be in B mode on the selection dial. The longest shutter speed in M mode is 30s.
Originally posted by Eruditass On your K-7, can you still get to bulb in manual mode or must you turn to B?
Same as the K10D, the K-7 must be in B mode for bulb; otherwise the longest shutter speed in M mode is 30s.
Originally posted by Eruditass I don't recall is the K10D has this. I also don't remember if the K-5 lets you do that without the remote.
No, the K10D doesn't. The K-7 and K-5 do allow one-press start, 2nd press stop, but only with a remote; it doesn't allow you to do so with the shutter button on the camera.
