08-16-2011, 03:32 PM   #1
Is the K20D OEM firmware supporting SDM lenses?
Sorry if this was asked before, but I was not able to find the answer.
For some reason, my friends K20D does work with SDM lenses. He bought it used. Unfortunately I do not know what is the Firmware version in the camera, nor have a picture taken with it. She is away on a trip and want me to find out if just by updating the firmware will do the trick.
Thanks in advance for your help.
08-16-2011, 03:46 PM   #2
dgaies's Avatar
Yes, all versions of the K20D firmware support SDM lenses.
If I recall correctly, it was the K10D that did not support SDM lenses until v1.3.
08-16-2011, 03:55 PM   #3
Yeah, the K20D should be fine. The K10D requires newer firmware, but the one I had worked just fine with my SDM lenses when I had it.
08-16-2011, 11:06 PM   #4
No issues with SDM lenses or powerzoom and the K20D with factory firmware. As stated by previous posters, only the K10D needed a firmware update to use the new motorisation.
There should not be any issue with DC lenses as well, they use the same power connection (but I never tried them on my K20D, I do not own such type of lens)
08-17-2011, 07:44 AM   #5
Blue's Avatar
Are you sure it isn't the lens?
08-18-2011, 01:07 AM   #6
Raffwal's Avatar
According to your sig you have a K20D as well. Does the lens work with it?
08-18-2011, 09:04 AM   #7
Thanks all for your response. She is away and I can't test it in mine. It may be the camera because the lens works in a K10D form her coworker.
Let see what do I find when she gets back.
08-19-2011, 06:22 AM   #8
Does it not work at all, or does it work as a screw driven lens? Peter Zack had a K20 that he fried something inside and it stopped using these lenses as SDM and started using them as screwdriven lenses, but either there is a fault with a camera or the lens. My guess would be the lens.
camera, dslr, firmware, k20d, photography, sdm
For Sale - Sold: K20D Body + 2 OEM batteries (CONUS) idkjai Sold Items 6 12-29-2010 10:53 AM
Screw drive firmware for SDM lenses Russell-Evans Pentax DSLR Discussion 228 04-30-2010 10:28 PM
AF problems with SDM lenses on K20D? tcom Pentax DSLR Discussion 19 07-18-2008 07:55 AM
Which would you choose? SDM Lenses or K20D dancel Pentax SLR Lens Discussion 22 02-19-2008 04:01 PM
All times are GMT -7. The time now is 03:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
