11-29-2007, 01:28 PM   #16
The firmware update 1.10 added that plus a couple of other goodies:
Check out an illustrated PDf version here http://tinyurl.com/2srtmp
Here's a summary;
* Using the camera's built-in flash, you can now wirelessly control external Pentax flashes. Previously, you needed an accessory flash mounted in your camera's hot shoe, but now the built-in flash can act as a control flash.
* In autofocus select mode, you can program the AF button to instantly return to the center autofocus point.
* In Tv or Av mode, you can now program the second e-dial to adjust your ISO setting.
* In any exposure mode except Sv and TAv, you can change your ISO setting with the front e-dial while pressing the OK button. The camera will display your ISO in the viewfinder and on the top LCD panel as you adjust your setting.
* In TAv mode, you can program the green button to return to the camera's program line. Previously this functionality was only available in M mode.
* You now have additional options for programming your e-dials in P mode.
* Pressing the green button while adjusting flash exposure compensation will now return you to the default value.
* Corrected an issue in some rare cases where a long exposure might produce a vertical stripe.
* Corrected an issue where the battery charge indicator would sometimes show empty in bulb exposure mode.
12-01-2007, 05:21 AM   #17
Mechan1k's Avatar
QuoteOriginally posted by Peter Zack Quote
I've been using this for awhile and it's an excellent upgrade. The other thing I love about this camera's adjustablity is that in "custom setting" you can change what each E dial does with shutter, aperture and ISO settings to suit how you want the camera to work.
This is what makes the K10D such a flexible camera.
12-01-2007, 07:16 AM   #18
Thanks for that, didn't know this one - works on my GX10 too !!
simon
12-01-2007, 04:00 PM   #19
Great tip! And thanks to pcarfan for reminding me that you can set the rear dial in Av & Tv for ISO. That is one of the things that makes the K10D so great.
button, camera, dslr, e-dial, front, iso, k10d, mode, photography, shortcut, value
Manual flash but "P" mode in K10D? Zakovva Troubleshooting and Beginner Help 1 03-13-2010 09:57 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
Pentax "A" lens and "F" 1.7X converter on K10d yyyzzz Pentax SLR Lens Discussion 4 07-09-2009 05:04 AM
How to ISO in "P" Mode Stratario Pentax DSLR Discussion 6 05-12-2009 05:43 PM
Pentax K10D ISO setting "on the fly" tohcp Pentax DSLR Discussion 6 07-15-2007 06:23 AM
All times are GMT -7. The time now is 06:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
