08-23-2011, 06:26 PM   #1
eccs19's Avatar
Best ISO for K7
Just wondering for Dynamic range, is ISO 200 or 100 best on the K7. I was under the impression that ISO 200 was native, but not 100% sure.
08-23-2011, 07:07 PM   #2
I shoot with ISO 100 all the time in manual. 200 if overcast or sun down. 400-800 in low light. how will that affect dynamic range? Is that not something to do with the sensor?
08-23-2011, 08:01 PM   #3
Wheatfield's Avatar
QuoteOriginally posted by eccs19 Quote
I shot at 100 with the K7 simply because it was the least noisy speed. I'm pretty sure 100 has greater DR as well.
QuoteOriginally posted by Lifegofast Quote
Dynamic range becomes more limited the farther away from the sensor's native ISO you go.
08-24-2011, 02:18 AM   #4
Banned
I used the dynamic range expansion very often and with that iso200 is base-iso. You have more room preventing highlight burnout. Problem is getting more colournoise, so using hi iso settings will get a little dangerous.
08-24-2011, 03:24 AM   #5
Native iso for the K7 is 100. For the kx/kr it is 200. Dynamic range is greater at 100 than 200.l
08-24-2011, 04:58 PM   #6
eccs19's Avatar
Thanks for all the replies. I usually shoot at 100 when I can, but started wondering if I would be better at 200, as I thought it was the native ISO.
08-24-2011, 06:18 PM   #7
jpzk's Avatar
Still have my K7 and I very often shoot at up to ISO 500-800, in RAW, while trying to not undexpose.
That way, if any unwanted noise shows, I can always deal with it in PP.
In a nutshell, the K7 is quite capable beyond ISO 100-200 at least to ISO 640-800.
My ten-cents.
JP
08-24-2011, 06:49 PM   #8
twitch's Avatar
Forget native ISO, that old myth is perpetuated both those who don't know how to read DXO graphs and love "just so" stories.
Shoot at the lowest ISO for the least noise and the greatest DR; ISO 80 is better than ISO100 is better than ISO200 on any given Pentax body regardless of what the native ISO is.
08-30-2011, 03:48 PM   #9
kh1234567890's Avatar
With the K-7 and shooting RAW I find that without using the 'highlight correction' the camera tends to ever-so-slightly clip the blacks, highlights aren't usually a problem. Turning on the 'highlight correction' seems to give a couple of bits of headroom both in the shadows and in the highlights. It does limit you to ISO200 and above with a very slight noise increase over fixed ISO100. Usually I leave the 'highlight correction' on and limit the ISO to 200-800 with 'Auto ISO' on 'slow'.
camera, dslr, iso, k7, photography
I am getting a lot of noise at ISO 800 and ISO 1600.... Abstract Pentax K-5 19 11-30-2010 10:48 AM
[Auto-ISO] so, is the K5 and Kr brave enough to use max iso? Reportage Pentax K-5 13 10-24-2010 03:30 PM
K-5 vs K-7 First ISO performance testing (ISO-6400) starscream Pentax News and Rumors 95 09-25-2010 07:02 PM
Default ISO 200 vs ISO 100 joodiespost Troubleshooting and Beginner Help 6 01-09-2010 05:50 PM
ISO ranges and low iso, techies please look. Gooshin Photographic Technique 7 09-09-2009 07:37 PM
All times are GMT -7. The time now is 06:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
