11-29-2007, 11:24 AM   #1
jshurak's Avatar
K10D + old Manual Focus lenses
Now I know you can set the K10D to work with the aperture ring. I set it up once with an old lens I had. Tamakur 50mm f/2 to be exact. If memory serves me correctly, it worked, but the light meter didn't work and the aperture wasn't displayed. Did I do something wrong? Or is that how it goes?
11-29-2007, 11:44 AM   #2
jshurak's Avatar
My apologies for not scrolling down in the threads! My question was answered here.
11-29-2007, 11:59 AM   #3
Lowell Goudge's Avatar
With Old K Mount lenses you have no apature information because there are no electrical contacts to read maximum apature, and no lever to read the setting.
As a result, metering also does not work, BUT if you hit the Depth of Field switch (on the K10D the power switch rotated furhter) the lens stops down, and the light meter activates, you can then adjust shutter speed (with the dial) and apature on the lens to balance the exposure, like old fashioned matched needle metering.
You will also when the lens is stopped down, see the background focus change.
In AV mode, the lens will NOT stop down during exposure, regardless of apature ring setting, and the exposure will be based on wide open apature.
In Manual mode, pressing the green button will set the shutter to the correct speed for the lens apature, and will take the shot at the F-stop set on the lens..
I think this answers all the possible questions on K mounts.
With M43 lenses, when you stop down the lens the apature changes at the same time since there is no actuating lever to hold it open. As a result, you focus wide open, (easier to focus with bright view finder) stop the lens down, and in AV mode press the shutter and the camera sets the shutter speed corectly.
aperture, camera, dslr, k10d, photography
K10D - Setting Shake Reduction Focal Length With Manual Focus Lenses? stewart_photo Photographic Technique 30 07-28-2016 12:52 AM
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
Inexpensive lenses to try Manual Focus? Todd Adamson Troubleshooting and Beginner Help 87 10-29-2010 04:56 PM
Manual focus lenses on K7 kayaka Pentax SLR Lens Discussion 4 06-08-2010 09:37 AM
Manual Focus Lenses and K100D throndor Pentax SLR Lens Discussion 2 10-14-2008 02:27 PM
All times are GMT -7. The time now is 03:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
