08-30-2011, 07:13 PM   #1
ducdao's Avatar
How do I use external TTL flash on the *ist D?
Hi guys - I just acquired the *ist D simply to leverage all my external TTL flashes. This is my first time using the TTL functionality so I'm not sure how to make it works properly.
Let's say I have the following setup:
- *ist D ==> Mode = M, ISO = 400, shutter = 1/125 as it won't sync beyond that
- M50/f1.4 ==> F5.6
- Nikon SB28 flash
Now the question is: what do I set on my SB28?
I'm pretty sure I need to set the flash mode to TTL but do I need to set other parameters (focal, ISO and aperture) to match with the camera of it does on its own?
08-30-2011, 07:38 PM   #2
I'm not a flash expert, but you should just be able to use the flash in TTL mode- the camera will do everything else for you. That's the beauty of TTL, as it measures light in real time rather than performing calculations in advance.
08-30-2011, 08:44 PM   #3
TTL requires "dedicated" flash. Nikon flashes are not dedicated to Pentax cameras.
08-30-2011, 08:50 PM   #4
Ah!! No!!
You will NOT be able to use a Nikon SB28 flash in TTL mode on a Pentax camera.
If the flash has an sensor in the flash you should be able to use the flash in Auto mode, where the flash controls the amount of flash delivered.
You should also match all settins on the camera on the flash ISO, aperture, focal length if that can be set on the flash.
regards
Chris Stone
08-31-2011, 04:24 AM   #5
We're talking TTL here, guys, not P-TTL...
Some (not all!) Nikon flashes do have a SU-4 slave setting that allow them to piggyback on whatever TTL flash there is, so yes, they are compatible with our old TTL Pentax bodies.
For those that don't have the SU-4 functionality, well, you can always buy the SU-4 module it was named after...
I've made a thread on this some time ago : Pentax TTL bodies with Nikon flashes.
I tried with my MZ-7 film camera, and it was simply perfect. Maybe needed a little -0.7 Ev comp for my taste, but otherwise, it was working straight from the start.
Unfortunately for you, from memory, the SB28 does not have this feature... So you'll either have to get a SU-4 module, or buy another Nikon flash (the SB50Dx is a good choice, as it's practically brand new and is not compatible with current Nikon DSLRs)..
08-31-2011, 06:35 AM   #6
ducdao's Avatar
I got it. I also have two genuine Pentax flashes that support TTL natively, AF360 FTZ and AF500 FTZ. I will try those under TTL mode then.
The SB28 has A mode so I will use it under Auto mode instead.
Thanks guys!
08-31-2011, 08:46 AM   #7
Lowell Goudge's Avatar
ducdao
you are correct, you need a flash that supports TTL, but it does not need to be the AF 500FTZ (although that is a fine flash) or the AF360FTZ.
The AF540FGZ will also support TTL mode providing the lens on the camera is NOT in the A position.
ALso, and someone needs to confirm this, if you are in TTL mode with the internal flash, some nikon flashes can trigger and both turn on and off remotely, based on the flash duration of the prime (on board flash)
As a result, you can use the internal flash as the master, and the nikon flash as an off camera remote slave, in TTL mode.
Again, for the internal flash to work in TTL mode the lens MUST NOT be in the A position
09-01-2011, 12:30 AM   #8
Lowell, I confirm, this is the SU-4 mode found on Nikon flashes... It's named from the SU-4 module you can plug on nearly any Nikon flash, thus adding this features on any model you have...
In newer flashes, the SU-4 mode was added in the flash itself...
I've tried this mode with a MZ-7 film camera using a Porst 55/1.2 PK lens and a Nikon SB-800, and exposure was great (if maybe a little overexposed, but a -1Ev Flash comp would take care of this)...
I used a Nikon SG-3IR to prevent the internal flash from contributing to the exposure.
09-01-2011, 05:31 AM   #9
QuoteOriginally posted by dlacouture Quote
I suppose with a TTL external flash, you could always point it up or away from the subject but still use it as the master, and avoid direct lighting also. But the point is, the SU-4 mode is what I was referring to, and you have confirmed it works.
09-01-2011, 01:15 PM   #10
For reference, Flashes including the su-4 mode are (AFAIK):
- SB26, SB30, SB50 and SB50DX, SB80DX (and maybe others, but these are the only ones I could identify)
- The whole DSLR SB line (SB600, SB800, SB900...)
Have a look through This site dedicated to Nikon flashes...
09-01-2011, 01:19 PM   #11
ducdao's Avatar
Darn, I have SB22, SB24, SB25 and SB28. I guess I'm not too lucky with TTL then
I just love those old Nikon flashes, they are so well built and always deliver when needed.
09-01-2011, 04:33 PM   #12
You can always try to snag some SU-4 units, they go for 100€ brand new, 50€ second hand...
*ist, camera, dslr, flash, iso, mode, photography, sb28, ttl, ttl flash
Difference between TTL and P-TTL flash. rod_grant Pentax DSLR Discussion 46 11-15-2017 10:05 PM
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
*ist DL2 + External Flash + Radio Trigger = Problems Jim Royal Photographic Technique 2 10-27-2007 07:33 PM
*Ist DL and TTL flash Matjazz Pentax DSLR Discussion 28 01-15-2007 08:09 PM
All times are GMT -7. The time now is 01:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
