Hi, I've looked at your pictures.
The ones I like are the boy at the surf, the girl with sunglasses and the yawn.
The others are, well, too much as if taken from the point where you usally approach a subject.
Try changing your composition and more also try to change the angle you take a photo.
What I like is some mistery.
I'm not a pro and not the best photographer around, but this is what I mean:
The darkness and the light in a diagonal makes it different.
Or this one:
I could have stand right in front of the temple, which I also did when we were there, but this picture has more character.
Or here:
The blade in front gives the picture a different dimension. It would have been better if I were less in front of the boat.
Pictures at sunset or dawn are better than any other moment of the day:
Sunset:
Dawn:
Jsut before the sun came up:
No straight lines:
In many occassions it is better to move down.
Get the camera low, you'll create more depth.
Imagine this photo taken a 6 feet high, it would not have any depth:
The most valuable advise I can tell you is; experiment. Experiment *a lot*!
Find different angles, take a flower from the ground up instead top down, look for an angle you would not normally approach the subject.
Have fun, you are doing great!
Play more and enjoy yourself.
Don't worry, the delete button is right there...
Bert
