12-04-2007, 11:33 PM   #16
LaRee's Avatar
I'll take your word for it
QuoteOriginally posted by borno Quote
I use a couple of manual zooms a lot and if you set sr for the longest and then shoot wide it will over compensate and produce blur, but set for the short end like 35mm for my 35-70mm and it helps a bit at 70mm even if not optimal. don't take my word though test it for yourself. I was second guessing myself after reading this thread and had to double check- sorry I'm too lazy to post a bunch 'o pics of a duck decoy I was using to test on
I wasn't aware of this and I also will set SR to the longest focal length when shooting with a manual zoom. Actually I'm using a manual tc that makes my zoom a manual. I guess I haven't noticed it because if I'm using a zoom I'm most often at the long end? I'll have to take a wide shot next time I use the combo and check it out. Thanks for posting your results (even if I can't see them).
camera, dslr, photography
Do you always have shake reduction ON? gawan Photographic Technique 18 08-01-2010 02:36 PM
Shake reduction julianactive Pentax SLR Lens Discussion 2 05-06-2009 04:13 PM
shake reduction oatman911 Pentax DSLR Discussion 17 03-07-2009 04:38 AM
Thank you Shake Reduction! tcdk Post Your Photos! 4 09-03-2008 09:29 AM
shake reduction jay legere Pentax DSLR Discussion 7 01-20-2008 07:45 AM
All times are GMT -7. The time now is 10:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
