When you plug the battery in the charger, and switch on the charger, the green light must come on. Once the battery is fully charged, the green light shall go off. The charge takes easily 3-4 hours, possibly 5 hours..
For comparison, my fully-charged K-7 battery lasts 700 to 1000 shots without using the LCD nor flash, or any in-camera PP. Mine is 2 years old and still holds well after about 18,000 shutter counts.
Your problem might be:
- the battery is a 'dud';
- the battery charger is not charging properly; and/or
- the battery was not charged long enough.
I woudl check the contact on the battery, the contacts in the charger, and try again. If the green light is still on after 6 h, I would say that there is a pb and I would go to the local photo store for advice. (I add that the K-7 is a very simple, easy-going camera with very few problem. Yours is most unusual.)
Hope that the comment will help.
