my first attempt, early this morning, I managed to fit the shutter assembly, but couldn't quite gamble it was a successful positioning. I was true
That's why I reopened the camera and started to read in depth... to ask questions
Tomorrow I'll continue my work, but for now I'll update the things I tried. There is the motor that drives the gears(the mirror). In the service manual it states it needs 2V to action the mechanism. So I tried this thing and actually it's true
...maybe this it the way to check everything out after it's mounted.
I am thinking to do it this way:
- drive the motor/gears/lever/mirror to raised position. This way the lever gets to be in the most upper position
- fit back the shutter assembly. this should fit fine because the lever is all the way back
- connect the motor to a battery to check if it's functional.
Hope it works. I'll come back with results. I should also take pictures. I'm so thankful to people posting this kind on the internet....a lot of them helped me now
. Maybe I can explain my concerns directly on them.
I'm tying at first to understand how things work....but the only logic to how the shutter works is that beside the lowering/raising action of the curtains, there are tiny elector-magnets that control if the curtain should remain open or closed. Correct me if I'm wrong.
