Finally got around to my bird feeder remote trap test today. Basically that means setting the camera on a tripod relatively close to the feeder and then going back inside and triggering it via the remote. I noticed the birds dont care too much about the camera on a tripod as long as no humans are around.
so I set the drive mode to remote control and the red light starts blinking on the IR sensors to let me know its ready. But then it keeps timing out, the red light stops blinking and when it stops, pushing the remote control button does nothing.
And of course I found a nice correlation between the time it took for that to happen and the time it took for the birds to build up courage after they had seen me fiddling with the camera to wake it up.
Now my question, is there any way to delay that timeout. I tried increasing the meter time, but obiously that was not connected, then I set the camera auto power off to 30 minutes, but that didnt help either.
When I walked out to revive the camera, the camera was still on and ready, so I pressed the Fn button and found that the drive mode was now set to single shot, I changed it to remote control again and the light came back on, but after some minutes the same thing happened. That seems strange to me, why cant the drive mode stay as remote control for as long as the camera is active?!
