10-07-2011, 12:31 PM   #1
aT0Mx's Avatar
Processing times.
I know my K110D takes some time to process and save long exposures.
My questions:
Do the newer models have faster processing times?
-and-
What are the ratios for longer exposures?
10-07-2011, 12:39 PM - 1 Like   #2
Aegon's Avatar
Check out the following links:
Dark-frame subtraction - Wikipedia, the free encyclopedia
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/74669-dark-frame-subtraction.html
Every camera that is configured to perform dark frame subtraction on long exposures will take approximately twice as long per shot as you may expect. So even newer models will take a long time when performing dark frame subtraction.
You can turn it off, but then your image might have some undesired noise.
10-07-2011, 12:45 PM   #3
aT0Mx's Avatar
So it's just the Noise Reduction?
I'll try that.
10-07-2011, 01:06 PM   #4
wlachan's Avatar
The write speed of SD has impact as well.
10-07-2011, 01:48 PM   #5
aT0Mx's Avatar
That worked. That should make my time lapse better. Now I need an adjustable ND filter.
10-08-2011, 03:05 AM   #6
adwb's Avatar
QuoteOriginally posted by Aegon Quote
which you can remove instantly in most software during PP.
10-08-2011, 09:50 AM   #7
Marc Sabatella's Avatar
Regular NR isn't the best choice for the type of noise you get in long exposures, though. Dark frame subtraction is really a better method. While *some* software allows for that, it isn't as common.
10-08-2011, 11:02 AM   #8
aT0Mx's Avatar
With what I want to do with long exposure time lapse, I'm good with using a lower ISO and just staying away from the noise.
At 800ISO I get very little noise with 30 seconds, but max. I might require is a 10 second exposure.
camera, dslr, exposures, photography
Landscape Have seen better times Lab Photo Critique 11 04-12-2011 03:52 AM
Lens Correction: 15mm DA Limited (in-camera Pentax Kx processing or post-processing?) ADHWJC Digital Processing, Software, and Printing 10 11-29-2010 08:11 PM
Nature I was mooned! 3 times... forensicscientist Post Your Photos! 3 03-14-2010 05:49 PM
Landscape under the sea times three dcmsox2004 Post Your Photos! 3 01-28-2010 01:58 PM
Nature Tough times volley Post Your Photos! 15 01-18-2010 12:41 PM
All times are GMT -7. The time now is 08:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
