Originally posted by fg-one Comparing my K200D to a very recently acquired K5, I came to the conclusion that the K200D more easily produces in some situations pleasing (and realistic) colours. Here is one example, in mixed lighting.
Could I make a very simple suggestion?
This could be the difference in in Pentax's Image (Finishing) Tone.
I noticed going from a K100D to a K-x that Pentax seemed to make their default Image Tone "Bright"
noticeably less saturated and "bright".
On the K100D I normally use the Natural setting finding the default Bright setting too saturated -
whereas when I got my K-x - the default Bright setting was much less garish.
The Natural setting in comparison also correspondingly seemed more muted on the K-x than the K100D.
From
dpReview of Pentax K200D -
Quote: The K200D's color response was very similar to that of previous Pentax digital SLR's. The image output in the default 'Bright' image tone is quite highly saturated (vivid), as can also be seen earlier in this review. Switching to the Natural tone calms color saturation to more typical levels (compared to other digital SLRs).
Unfortunately dpReview changed their format for the Pentax K-5, so I can't find the equivalent comment -
but as perhaps an indicator of the Pentax trend -
this is from
dpReview of the K-x Quote: The K-x produces an almost identical color response to its bigger brother, the K-7. As we've seen in other reviews the standard hues are also very similar to most other SLRs in this class, with minor saturation and brightness differences but essentially the same color response.
Perhaps I ought to add -
this may seem to only apply to JPGs since that's what dpReview was testing -
but even in RAW both Pentax DCU (Digital Camera Utility) and probably LR seem to understand Pentax dSLR settings -
so the camera settings are carried over when the RAW image is converted -
unless one deliberately overrides the setting in pp.
