12-09-2007, 03:13 PM   #1
Syb's Avatar
E-dial is dead (*IstDs): what backup for K10d?
Hey,
The problem is clear. The only e-dial on my Ds is dead. Was already dead after +/- 3k pics taken (and a lot of digital zooming, I should admit).
Now here is the issue.
What camera will I take as a backup for my K10d? Many guys are glad with their K100Super, how is it compared to the options of the IstDs? On the other hand, the image quality of *Ds is more than satisfying. And it is relatively cheap on ebay... but it still has only one e-dial. And if it is flawed, too... I could get angry.
Any suggestions?
12-09-2007, 08:32 PM   #2
frank's Avatar
I think it's pretty easy to fix the E-Dial, it's just some dirt under the wheel. I know someone opened the camera up and fixed the problem quite easily. Or you can just send it to a service center for a fee. Won't cost too much to get it fixed.
Unless you want to upgrade already. I got a K100D as a backup of my K10D, quite like it.
12-09-2007, 09:14 PM   #3
Frank is right, it is just dirty. You can take yours apart even with the least amount of mechanical skill.
As for a backup to the K10, mine is the *ist D. It supports wireless flash with the onboard flash and has a TTL sensor. It also is more sensitive (than the K10) to IR light. Beware, though - it takes CF cards and is slow as molasses. Also, the menu isn't nearly as good or navigable as the K10's.
12-09-2007, 09:29 PM   #4
stewart_photo's Avatar
If you're satisfied with the IstDs, I'd recommend fixing it and not shopping for another camera. However, if you simply want a new camera, I'd suggest waiting another few weeks to see what the start of the new year has to offer (especially since you already have a good cameras in the K10D and the repaired IstDs). If you absolutely cannot wait (money eating a hole in your pocket), a second K10D body may be the answer (although, at this point, I personally would probably buy other, less expensive, accessories instead).
That's basically my overall game plan at the moment. I have two K10D camera bodies (primary and backup) and might replace one of those with a new camera body next year depending on the product offerings. Otherwise, I'll keep keep what I have. In the meantime, I'm adding to my overall system with new accessories.
stewart
12-09-2007, 11:10 PM   #5
Buddha Jones's Avatar
Fix it, and save up for the new body and make your K10D your new backup!
12-10-2007, 06:53 AM   #6
I agree with Buddah!
thanks
barondla
backup, camera, dslr, e-dial, photography
Faulty k10d mode dial Northern Soul Pentax DSLR Discussion 21 10-26-2010 02:05 AM
Cheap Backup Camera, *istDS/DL vs. K100D, etc skydragoness Pentax DSLR Discussion 24 07-15-2008 07:31 AM
K10D e-dial weirdness brothereye Pentax DSLR Discussion 15 05-07-2008 05:13 AM
Rear e-dial stuck on K10D Groundloop Pentax DSLR Discussion 11 03-14-2008 11:22 AM
K10D Aperature Dial jnorth Pentax DSLR Discussion 3 02-15-2008 07:45 PM
All times are GMT -7. The time now is 10:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
