Originally posted by daacon Well over the Lunch hour I brought her into the shop. Slapped in a known working good fully charged battery and Vola - Issue still exists
So I bought a new battery anyway - the one that comes in a new K10D body box
Looks like the Xmas LBA just turned into BBA . The good news (I suppose??) is I now have a spare everything for the body and soon even a spare body. My existing batteries in the new body show a full charge so all is good. Interestingly enough the new body still comes with Firmware 1.0 so the first thing was a quick upgrade. Also I think I changed some of the custom menu – will have to revist that.
The better news is even though I bought the camera used from a member on this forum (he gave me the original receipt) - the warranty is good. So the repair will not cost me anything. The bad news is it is the standard 4 - 8 weeks. The good news is the new K10D bodies are on sale for $649.00 almost half price of the one I brought in was worth when bought (March 08). The bad new is that was about $700.00 (taxes) I was not planning on departing with. The good news is I am back in the picture taking business.
I really think it was just a defect. I don’t think 15 minutes or so in extreme cold should have affected the body. I treat my equipment very carefully so I am pretty sure abuse or it being dropped is out of the question (unless someone else did)
Anyway if I get the camera back within 30 days I can return the new one. If not watch the Marketplace or I may just keep it who knows.
Thanks for the support and suggestions.
Hi Dave,
I am glad that you're able to take pics again
and I would recommend that you contact
the person you purchased the defective K10D off of and see if he/she will send the camera
back to Pentax (hopefully Canada) as they Pentax (Canada) should pick up shipping costs if
it goes back through the store it was purchased at originally. Also, seeing as how you have
the original sales receipt, you can try contacting Pentax Canada -- see below for contact info --
PENTAX CANADA 1770 Argentia Rd
Mississauga, ON , L5N 3S7
Phone: 905-286-5585
FAX: 905-286-5586
Like the majority of the others, I can't see 15 minutes of cold weather causing your camera
this much of a problem ....however, I can see bringing a cold camera into a warm house causing
a bit of a problem due to 'condensation' -- I lived and shot in Winnipeg for a number of years so I
know the 'cold > warm' problems
-- and if it is a 'condensation problem' then I believe that
would void the warranty and, if you wanted to go ahead with a repair, you would have to pay
for the repair
Another alternative is to contact the repair in Alberta, albeit Calgary, and see
if they can fix it locally -- if you are in (or near) Calgary -- click the following link and go to Repair Centre's
or you can fill out the form at the end and send your info to Pentax Canada in Mississauga:
http://www.pentax.ca/support/digital/index.php
Hope some of this helps and if you do go ahead with the repair hopefully it will be covered under
warranty
Cheers,
Jack
