10-13-2011, 12:25 PM   #1
K-X ISO 100 or 200
Background: I shoot raw and process with Pentax DCU. I use highlight correction and shadow correction as needed in post processing.
There seems to be a discrepency in information provided by DXOMark sensor testing DxOMark - Pentax K-x
The above data indicates higher dynamic range for 100 vs 200. Stepping through the various test results seem to indicate 100 is better than 200 in a lot of ways.
and Digital Photo Review K-X testing
Pentax K-x Review: 17. Photographic tests (DR): Digital Photography Review
The above data shows a slight lower "usable" dynamic range for 100 vs 200. It shows a little less highlight range for 100. The shadow range is the same.
What gives?
On p 91 of the manual they state "When the sensitivity is set to ISO 100, bright areas are more likely to occur". The Digital Photo Review data would support this.
I recently shot bright colored folliage in the sun and shoot at ISO 100 thinking it would be better based on DXOMark. I was pleased with the results. I was careful not to blow out a single color channel.
Bottom line when shooting RAW and using DCU which is bettter 100 or 200
Thanks,
Mike
10-13-2011, 01:16 PM   #2
snappychappy's Avatar
The difference between the two ISO settings is that small I wouldnt worry.
camera, data, dslr, dxomark, iso, k-x, k-x iso, pentax, photo, photography, range, results, review
Macros: DFA 100 WR, A 100 2.8, A* 200, Sigma 180, Sigma 150 atlnq9 Pentax SLR Lens Discussion 20 10-11-2011 12:26 PM
Sensitivity starting from ISO 200 why not 100? sany Pentax K-r 7 04-02-2011 12:48 PM
Iso 100 or 200 645d kuau Pentax Medium Format 4 02-13-2011 11:43 PM
Default ISO 200 vs ISO 100 joodiespost Troubleshooting and Beginner Help 6 01-09-2010 05:50 PM
iso 100 or iso 200 kiwao Pentax DSLR Discussion 8 03-05-2009 01:02 PM
All times are GMT -7. The time now is 02:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
