Originally posted by Tom M The reference to Firmware version 1.30 is to insure your's is up to date. I say this because some folks had experienced vertical banding and poor low-light performance with the K10D early on. Updateing the firmware, I believe at the time it was 1.10 or 1.20, seemed to fix the issue, so, since it doesn't make sense to download anything but the latest firmware, I mentioned 1.30 instead. If you don't want to download to see if it will fix your camera, that's fine with me.
Originally posted by Tom M All I can say is.. I 'expose to the right' as much as possible, just before blowing the highlights and I don't have any issues with banding or noise. IF I'm sloppy and don't properly expose, I get noise. As a side note, I use firmware version 1.00. I guess it all depends on who's taking the pictures?
Sorry am I misunderstanding you.....
do you have firmware v1.30 in your K10D or v1.00?
Originally posted by Tom M Most dSLRs perform quite admirably at high ISOs espcially when compared to the typical compact -
and I think the K10D does as well.
When used in good lighting even ISO1600 is hard to fault for any practical photo - again this is so for the K10D - so it's not really any additional revelation.
But the original contention was that the K10D does better than the K100D at high ISOs.
I'd agree about K10D's ISO1600 being better than the K100D's ISO3200 -
but still feel the K100D is better than the K10D at the same ISO1600 -
of course YMMV and opinions differ.
