10-24-2011, 04:04 PM   #1
K-X Auto Pict Mode
Howdy,
Hope someone here can help. It seems that whenever i put the camera in Auto Pict mode to take a really quick shot. 9 times out of ten its either too dark or way too bright. I thought Auto Pict was supposed to set everything for you? Is there a setting somewhere, maybe the White Balance that i need to adjust?
thanks!
10-24-2011, 09:02 PM   #2
Marc Sabatella's Avatar
Too dark or too bright is subjective. Auto pict tries, but there are never any guarantees the results will be exactly what you want. If you want to picky about what you want, then you pretty much to learn ow to take control yourself via the other modes.
10-29-2011, 06:36 AM   #3
What's your iso set to? Even in auto you still set that and the camera does the rest.I find on mine that for a quick shot it's better to use the manual setting but press the green button to set ap. and shutter speed. Seems to give much better results than full auto for some reason, and also works well for the old manual primes I mainly use. It's always worth setting the WB too, I just pop a quick shot of the scene and adjust from there. With only a tiny bit of practise you'll find you're able to predict what setting to use before you even start shooting - I find I mainly use the fluorescent settings for general use, and I've found that the flash setting is a pretty good place to start from for mixed lighting.
10-29-2011, 10:21 AM   #4
kardinal's Avatar
If I need a quick shot I tend to just use Av mode. If it's too under/over exposed I can just change the compensation quickly and go from there.
auto, camera, dslr, mode, photography, pict
SLOW continuous shooting on all modes except auto pict? tensai Troubleshooting and Beginner Help 5 08-30-2011 09:13 PM
Auto Pict always shoots at 6400 ISO?? Silverkarn Troubleshooting and Beginner Help 5 08-26-2010 01:51 AM
Auto Pict and "P" SweetSherri Troubleshooting and Beginner Help 12 05-09-2010 06:33 AM
No More AUTO PICT! Music Photographic Technique 17 01-10-2009 05:49 AM
K100D: Diff Between P and Auto Pict Modes? atnbirdie Pentax DSLR Discussion 9 06-24-2007 06:00 PM
All times are GMT -7. The time now is 05:45 PM. | See also: NikonForums.com, part of our network of photo forums!
