12-20-2006, 03:53 PM   #1
clarenceclose's Avatar
SR working or not.
I am having a time determining if the SR is working or not.
My hand shake could be so bad that it cannot compensate.
Take close up pictures and they look very similar so no help there.
Put it up to my ear, turned it on and I cannot detect any noise, vibration, etc. with or without the shutter button half pressed.
Any clear way to test this for SR?
Thanks
12-20-2006, 04:09 PM   #2
Put focus to continuous, drive to continuous and let rip with a sequence of 20 or 30 shots (jpg's) at maximum speed. Sooner or later, you should hear the sensor kind of shift - almost as if it's re-centering/resetting itself. At least, that's what I'd hear on occasion when I was shooting the geese yesterday.
12-20-2006, 04:33 PM   #3
Just take two shots of some text at 1/6s, one with and the other without SR. You should see results
12-20-2006, 05:06 PM   #4
-=JoN=-'s Avatar
yep..what mo said...
I know my hand holding limit in terms of shutter speed, so anything past that, i know it's working
12-20-2006, 05:22 PM   #5
WMBP's Avatar
QuoteOriginally posted by clarenceclose Quote
I've been wondering the same thing. My very rough and untested impression is that the optical image stabilization in my late great Canon S3 is better than the shake reduction in the Pentax K100D. But I did take Mo's advice just now. Took two pictures with the same exposure (1/6 second), handheld, one with SR on, one with it off. Results are obvious.
Perhaps I should add a personal note. I'm neither as young nor as athletic as I was once, but I don't think of myself as having a very noticeably shaky hand. I have had great results in the past using my S3 with long telephoto shots, handheld. But I took a number of test shots just now and the two I'm displaying are representative of the averages.
Will
P.S. For both photos: FL = 55mm; aperture f/16; shutter 1/6s; ISO 1600. Used Tv (shutter) mode.
PENTAX K100D  Photo
PENTAX K100D  Photo
12-20-2006, 05:52 PM   #6
Sluggo's Avatar
There are always other options if SR is working but turns out to be insufficient for you.
12-20-2006, 06:06 PM   #7
There was a video on the web showing the sensor moving.Think they just took the lens off and set a focal legth on the SR menu. Put camera on manual exposure about 1/2 second and shake and shoot the camera while looking in thru the lens mount. That sensor was moving all over the place in the video!
thanks
barondla
12-20-2006, 06:11 PM   #8
SR Works
Thanks so much. Took an old guy picture of 'fiber'.
Checked it under poor lighting at that and there is a very noticable difference.
Left SR off Right SR on.
12-20-2006, 06:14 PM   #9
QuoteOriginally posted by Sluggo Quote
Looked at this sometime back.
Portable tripod gyro.
Thought I might have to resort to that puppy until this SR in the body came along.
From what I read they are pretty noisy but they work as video dudes use them to shoot from heliocopters and get some pretty amazing shots.
Thanks everyone for your help.
12-20-2006, 06:52 PM   #10
WMBP's Avatar
QuoteOriginally posted by WMBP Quote
This thread has got me wondering about what I said above. I really do have the FEELING that the IS in the Canon S3 IS was "better" than the SR in the Pentax K100D. I say this because with the Canon I was able to take sharp pictures, handheld, with lenses that had greater magnifying power than the lenses I'm using with the Pentax.
But I've begun to think about this. It might be that the S3's image stabilization is [not] technically superior, but rather (or also) that the shorter focal lengths of the compact camera provide a benefit in this regard. We all know that camera shake becomes more noticeable in telephoto shots at 300mm than with normal shots at 55mm. Well, for the same power of magnification, the compact S3 has a rather shorter true focal length than a digital SLR. And that would mean that the same degree of shakiness would affect the shot less dramatically. The same tiny twitch will cause a 12-inch ruler's other end to move only slightly, but might cause quite a movement at the other end of a yard stick.
Or so I'm thinking. Am I reasoning correctly? Or am I overlooking something? I've been slightly disappointed with the image stabilization (SR) coming to the Pentax from the Canon S3, but now I'm thinking it may just be inevitable and NOT a sign that something is wrong with the camera.
Will
P.S. Edited this message after posting it originally, by adding the word "not" that is in brackets before "technically superior." My point is that the S3's image stabilization may NOT be better than the Pentax K100D's, but it has less work to do because of the S3's shorter focal lengths.
Last edited by WMBP; 12-20-2006 at 08:06 PM. Reason: added a missing "not" before "techincally superior"
12-20-2006, 07:58 PM   #11
slip's Avatar
But I've begun to think about this. It might be that the S3's image stabilization is technically superior, but rather (or also) that the shorter focal lengths of the compact camera provide a benefit in this regard. We all know that camera shake becomes more noticeable in telephoto shots at 300mm than with normal shots at 55mm. Well, for the same power of magnification, the compact S3 has a rather shorter true focal length than a digital SLR. And that would mean that the same degree of shakiness would affect the shot less dramatically. The same tiny twitch will cause a 12-inch ruler's other end to move only slightly, but might cause quite a movement at the other end of a yard stick.
Will
I think you are definately on to something. I do remember reading a review of the S3 and the lens is not very long, but when you put in the multiplication factor because of the small sensor, a short lens becomes a long telephoto.
randy
camera, dslr, photography, sr
Working with the K-x (or even the K-5) DRabbit Video and Pentax HDSLRs 6 02-21-2011 04:14 AM
Macro I'm Working! eaglem Post Your Photos! 3 05-21-2010 07:37 AM
K-X sr working? bullwhip Pentax DSLR Discussion 6 01-20-2010 12:44 AM
How to tell if SR is working? slow2focus Troubleshooting and Beginner Help 14 12-21-2009 09:49 PM
survey: batteries working/not working with the K-x noou Pentax DSLR Discussion 25 12-03-2009 02:43 PM
All times are GMT -7. The time now is 05:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
