Originally posted by Ole As has been mentioned, you could consider an older Pentax flash.
The AF280T can be had for about $60. Twice that will buy you the AF400T.
These will give you manual flash with several settings of the power, and autoflash (not P-TTL), where the flash sets camera shutter speed and aperture, and decides the exposure.
In my view the loss of P-TTL is not a great deal.
With the Pentax flashes you don't have to worry about trigger voltage being too high.
I think the AF280 is a great little flash for the money. If you want some sort of protection in buying one, you might see if KEH has any. They are great to work with and always rate their items conservatively such that you get something just a little better than what you expect (in my experience).
I have the Sigma Super 500 DG P-TTL flash, and after re-chipping, it works fine on all of my Pentax DSLRs (DS, K100D, K10D). I have zero problems with it, and all functions work fine (HSS, auto-ISO, second curtain and so on).
I think some people maybe do not realize that some Sigma 500's need to be re-programmed to work correctly with the K10D.
Also, I always make sure to turn off the camera and flash, mount the flash, turn on the camera and then turn onthe flash to make sure that the camera and flash talk properly. This may not be necessary, but I have had no problems with the combination, so it cannot hurt.
Lastly, you might consider looking for a used Nikon SB-24, 25, 26, 28. They are very well built flashes that have an auto mode, lots of features and power and in auto or manual, and they work just fine on my Pentax bodies. You have to set the zoom manually and the ISO/F stop you want as well, and you lose HSS but that is true of almost any auto flash if you choose to go that way.
I have to second the statement that PTTL is not a great loss, IMO. HSS is useful and not having to set the ISO and aperture is nice, but the PTTL system is pretty inconsistent and I get lots of eye-blinkers when I use it due to the delay between the pre-flash and the main flash.
YMMV, of course.
Ray
