Originally posted by Robin127 What I would like to know is there any advantage/disadvantage to using the lenses that don't have the "A" setting on the ring and manually setting the aperture on the lens as one would with a film camera?
Con: You have to slow down a little.
Pro: You have to slow down a little!
Let's look at the 3 sorts of MF lenses for Pentax: A-type, M-type, and what I call K-zero type. A-type can be used in any auto-exposure mode; you can let the camera worry about exposures. M-type work either wide-open in any auto mode, or with Green button stop-down metering and exposure in M mode. You gotta THINK about using it. K-zero type, on adapters usually (M42-PK or T2 or cheap macro tubes etc) have no auto-stop-down at all. Such can be used in Av or M (or B or X) with a level of mental involvement somewhere between (or beyond?) A- and M-type usage IMHO.
A gross oversimplification: M-type puts you closer to picture-making; the others, to picture-taking.
Quote: The 28mm and 50mm are both Pentax, the 28-70 is a Cosina and the 200 is a Soligor. I have found a problem with the Cosina, it doesn't seem to lock onto the camera body properly, in fact it can be twisted off easily without depressing the lens release button. It seems rather odd as it fits and locks perfectly to my P30T.
I use a cheap PK macro tube set as a test-bed for PK lenses and adapters and mods. Inserting the PK lense into the tube mount section, I can watch the blades and flags and locking pin engage (or not). You might check the Cosina, see if the locking notch is a different diameter than your dSLR's locking pin, and use such a macro tube to see how it actually engages (or not).
