This is quite a noob question but I'd just like to ask, as I saw this feature on a Canon compact... and thinking if my K-x can do the same...
Can the pictures, on playback, rotate automatically depending on how you're holding the cam?
e.g. You took a photo in portrait orientation and then pressed playback. When you're holding the cam horizontally it displays vertically, zoomed out to fill only the height of the screen, then when you hold the camera vertically the image rotates to fill the screen? Is that what "auto image rotation on playback" does? 'cause I was thinking that it might be also a K-x feature that is just not working with my unit and would have to have it repaired before warranty expires >_<
Reason: corrected some words
