That sounds like a battery problem.
Try an other lens first,
Make sure the battery is fully charged.
Make sure the contact on the battery are clean,use eraser not sandpaper.
if all failed, go to your local store and try a different battery.
If the problem still exists, the camera could be the issue.
Originally posted by jvp Hello,
I am having issues with my LCD turning off randomly when I am in the Menu.
I just received my K10D from B&H on Friday evening. I tinkered with it around the house a little, it seemed okay, then I put in my camera bag. Today, Sunday, I went to use it and the LCD shuts off at random when I am trying to use the Menu functions. It stays on if I use Playback or Function buttons. I cannot navigate through the menu at all because it goes off as soon as it turns on. It has not been dropped, bumped, wet, etc etc.
Anyone else had this issue? Sometimes it turns right off after a fraction of a second, other times it will turn off after 2 seconds or so. This is what I've tried to no avail:
* Removed battery
* Removed SD card
* I think I was able to get to the "reset" in the menu once; I reached it, and when I pressed "okay," but the screen went blank and gave no confirmation...
Thanks for all your help!
BTW, setup is:
K10D, OEM battery, SanDisk 1G Ultra II plus USB, Sigma 24-70 2.8 DG EX
Thanks again
