11-22-2011, 05:53 AM   #1
K7 questions
Couple quick questions. When reviewing images on the lcd or on the computer or tv, there is a black bar at the bottom if tje image, normal? Solution if not? Also, when does the copyright information appear on tje image? Thank you for the help.
11-22-2011, 06:16 AM   #2
The LCD has an aspect ratio of 4:3 but the image is 3:2. Therefore there is some unused space at the bottom. I suppose all APS sized DSLRs behave this way.
The copyright information can be configured in the setup menu. (Menu 3, item 1)
11-22-2011, 06:35 AM   #3
Wheatfield's Avatar
To be specific, copyright information doesn't appear on the image, it is embedded in the meta data of the image. A program such as PhotoMe can read the meta data.
11-22-2011, 07:51 AM   #4
Lowell Goudge's Avatar
I think you are referring to the bottom 1/4 inch of the rear LCD, which , depending on the info setting when you look at the images in full format, would be used to show the exif data,
this line disappears when you zoom in
11-22-2011, 02:32 PM   #5
Nass's Avatar
Can you clarify or post an example? You say you get a black bar on all output devices including computer? Do you mean when you've moved the image over, or using a cable (rgb/hdmi) to display it directly onto another screen?
camera, dslr, image, photography, questions
K7 Questions ecoronin Troubleshooting and Beginner Help 43 07-24-2011 09:09 AM
Some Advanced K-7 Questions jeffshaddix Pentax DSLR Discussion 8 08-11-2010 11:29 PM
Some questions for the Pro's Ivo_Spohr Troubleshooting and Beginner Help 8 03-19-2010 03:18 PM
Questions about the Pentax Universe Snowvent Troubleshooting and Beginner Help 9 01-08-2010 12:17 AM
USER mode for K7 ... questions. jpzk Pentax DSLR Discussion 9 12-29-2009 12:38 PM
All times are GMT -7. The time now is 08:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
