11-22-2011, 02:40 PM   #1
Nass's Avatar
curious about sensor temperature
It's a bit of a pain that the cam switches off liveview after x amount of time, which I believe is temperature related and governed internally programatically. Just for my knowledge, since I've noticed that this happens both when using HDMI out (which switches the on-cam screen off) and without a monitor (ie leaving the on-cam screen on), am I right in supposing that there's really no bodge way of switching this off or making it last a little longer without it overheating - since it's just sensor temperature and unrelated to heat put out by the on-cam screen?
Ta
11-22-2011, 04:45 PM   #2
Lowell Goudge's Avatar
QuoteOriginally posted by Nass Quote
Ta
Are you sure it is time or really temperature? Given the wide operating range of operating temperature a temperature related shut down wouuld make more sense
11-23-2011, 03:09 AM   #3
Nass's Avatar
Yes I believe it's temperature triggered, although there does seem to be some randomness about it. Ie sometimes the LV stops after a few seconds and then when I switch it back on it lasts for a few minutes... Annoyingle erratic.
11-23-2011, 04:52 AM   #4
sterretje's Avatar
That does not sound temperature related; I doubt that the sensor will cool down enough in a short period of time (assuming you more-or-less immediately switch it back on).
11-23-2011, 06:03 AM   #5
thoughton's Avatar
I have a vague memory that sensor temperature is shown in the full exif? That might cast some light on it. (Edit: no pun intended :P)
11-23-2011, 08:42 AM   #6
Banned
Temperature can be found in the exif of jpg at least. I think it is time related, but I'm not shure. The hottest working temperature I had with K-5 was 42 degrees of celsius, working for a hot afternoon sitting in the sun with my gear. No use of movie or liveview, but I guess it would have told me that it is hot outside.
11-23-2011, 09:21 AM   #7
Nass's Avatar
Yeah it's a bit of a weird one, the LV durations seem a bit random. RonHendriks do you get the same or is it a K7 thing?
11-23-2011, 12:14 PM   #8
Banned
This was with K-5.
Just looked in the manual and there it is: Liveview is activated for a max of 5 minutes after that you can press the button again and have liveview activated for the next 5 minutes. So it has nothing to do with temperature (in K-5).
11-24-2011, 04:51 AM   #9
Nass's Avatar
I checked my k7 manual and it's the same, up to 5 minutes. There's the rub though because "up to 5 minutes" can mean anything from a few seconds to a solid 5 minutes... Which is what seems to happen, it's pretty random
camera, dslr, photography, screen, sensor, switches, temperature
using dslr to determine light temperature? slip Troubleshooting and Beginner Help 3 04-05-2011 09:27 AM
K10D can tell temperature?! FlannelSpoon Pentax DSLR Discussion 10 02-19-2011 11:50 AM
K5 metering and color temperature woes MrPetkus Pentax K-5 17 02-03-2011 07:12 AM
Lens operating temperature Xlusionist Pentax SLR Lens Discussion 5 08-10-2010 07:17 PM
...and the current temperature is ... J.Scott General Talk 46 02-02-2010 06:59 AM
All times are GMT -7. The time now is 08:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
