11-28-2011, 08:44 AM   #1
ducdao's Avatar
K20D pop-up flash doesn't pop up!
Hi guys - well the title says it all. I tried to press the flash button and it doesn't do anything, tried all the different shooting modes, nothing.
Maybe it's just stuck there? Anyone has they same issue and knows how to fix it? I mainly shoot with external flash but sometimes the pop up is useful when I don't have the external flash with me.
11-28-2011, 10:29 AM   #2
drougge's Avatar
Shooting mode doesn't matter, the button is 100% mechanical and works with the camera off. Your flash is either stuck (spilled something sticky on your camera?) or the spring that raises it is broken. (Or maybe the button isn't connected to the hook that holds the flash anymore, I suppose.)
Try pressing the button and lifting the flash between your fingers, or even just holding the camera upside down.
11-28-2011, 12:10 PM   #3
ducdao's Avatar
QuoteOriginally posted by drougge Quote
OK, thanks. You make perfetly sense. I'll try lifting the flash with my finger tonight. The body was never dropper nor spilled anything on it. I don't remember whene was the last time I used the pop-up flash it seemed working before...
11-29-2011, 07:57 AM   #4
ducdao's Avatar
Update: I tried what drougge suggested by pressing the flash button and lifting the flash with my fingernail and it worked! When the flash popped up I heard a sound like it was depressuring, my guess is the WR suction that was making the flash to stuck...like I said I haven't used the flash for a while
Now, everything is working as it should.
Thanks druogge for the suggestion!
camera, dslr, flash, photography, pop
K-x and pop-up flash rajubhai55 Pentax DSLR Discussion 12 07-11-2011 07:44 PM
Flash on K20D won't pop up, help skien68 Troubleshooting and Beginner Help 2 04-04-2011 12:50 PM
Help! KX Pop-up Flash TAP Pentax DSLR Discussion 2 05-26-2010 01:06 PM
K7 pop up flash @#%! ordinaryimages Pentax DSLR Discussion 12 04-05-2010 02:55 PM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 01:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
