11-28-2011, 09:09 PM   #1
blank frames on K20D
Out on a shoot yesterday and my camera started to return blank frames. Monitor black but showing normal aperture and shutter speeds when reviewing. I was using the AF540 flash connected by pentax cable. I tried all the flash modes, put the flash directly on the camera but success. Luckily it came good again with a few odd intermittent blank frames just to annoy me. Anyone got any clues on what happened? I had the vertical grip and two fully charged batteries. If this continues I'm afraid I will be leaving Pentax for good.
11-28-2011, 10:27 PM   #2
The intermittent frames might suggest that the flash wasn't putting out enough power, but unless you're trying to shoot something far away at night that should almost never be the case...
11-29-2011, 01:09 AM   #3
Possibly that flash was charging at the time that the blank frame ocures? There is a setting that prevents the camera from taking pictures while the flash is charging; default is to prevent it but you might have changed it on purpose. I did that as well and sometimes the result is indeed severely underexposed images because the camera takes the shot while the flash does not fire (or barely fires).
Time to change batteries
11-29-2011, 05:21 PM   #4
Sorry guys, I forgot to mention it was daytime and the flash was only used for fill. Data on back was showing 1/90 and f4.5 so I should have been seeing something. I hope I can get to the bottom of it as it is a great camera otherwise. As I am doing more and more fashion stuff I am tempted to change to Canikon but dread the expense.
camera, dslr, flash, frames, pentax, photography
Help! Pentax 67 blank frames/shutter issue kkado Pentax Medium Format 6 03-02-2011 08:04 PM
They said my film was blank ? spystyle Film SLRs and Compact Film Cameras 33 04-25-2010 08:14 PM
k20d blank monitor raindear Pentax DSLR Discussion 9 09-17-2008 05:25 PM
K20D - Occasional blank captures Quicksand Pentax DSLR Discussion 2 08-18-2008 11:33 AM
K20D - viewing ISO and frames remaining info Arpe Pentax DSLR Discussion 7 04-16-2008 04:10 PM
All times are GMT -7. The time now is 10:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
