Originally posted by d.bradley There is also a method of enhancing the red channel by using data from the 'opposite' colour channel, in this case green. The basic principal is to take the textures from the green channel, mix them into the red channel, then colour shift back to the original hues. (snip)
That's truly impressive, d.bradley. Perhaps the best results I've seen from the various methods out there. Now if I could only understand what you've done. I'm not unfamiliar with graphics programs, but a rank beginner when it comes to Photoshop. As a result, I've gotten completely lost several times while trying to follow your description.
So, when or if you get the time, how about walking through the process with some rudimentary step-by-step instructions? Such as...
1. Select this or that.
2. Select the entire image and copy it.
3. Go to this or that tab and select it.
4. In that tab, select this or that (add notes in parenthesis or whatever as needed).
5. Etc...
I most certainly would appreciate the effort and it would likely help others as well. Thanks.
stewart
