Thanks for the advice, Adam.
I don't know if your "works" meant "works exactly as it did before" or simply "takes pictures." I went into Menu > Using Aperture Ring > 2 Permitted, and now the camera is working exactly as it did before — that is, it's autofocusing and doing everything else.
The only thing I notice being a bit strange is the exposure meter that tells you if a shot is going to be too dark or too light. It seems to be really jittery.
Do you think this is still an indication that the camera is failing? [EDIT: Well, something is definitely wrong, because going back to Using Aperture Ring > 1 Prohibited resulted in the K-10D shutter problems again.]
Reason: Afterthoughts
