12-23-2011, 05:17 PM   #16
Lowell Goudge's Avatar
QuoteOriginally posted by tuggie76 Quote
Hi Lowell, I think I'm missing something here. On my k200d there is a switch just below the raw button the has Mf & AF, is there another switch or a way to control this?
Thanks.
Tuggie
sorry if I confused you. The k10 and *isdD have 3 positions. Follow Marc's advice
12-23-2011, 05:42 PM   #17
Thanks guys, I understand now,I think!
Tuggie76
12-24-2011, 09:17 AM   #18
bluestringer's Avatar
On the K200D you must first set catch in focus to yes in the custom menu, it's number 22. Then set the focus switch to AF.S. Hold the shutter button down all the way with a manual focus lens and it will fire when focus is achieved.
12-24-2011, 09:42 AM   #19
On the K200D, just put the switch in the AF position. Assuming it is otherwise set up for manual lenses, you are now in catch in focus mode - press shutter button, picture won't be taken until something is in focus.
Thanks Marc
12-24-2011, 11:19 AM   #20
RioRico's Avatar
QuoteOriginally posted by pkdick2 Quote
I think it's a silly thing not to enable all focus points with A lenses. That would be nicer in order to use the "catch in focus" setting and would allow easier composition.
The problem with a 'matrix' CIF is that the shutter would fire whenever ANY of the focus points had a hit. Now, if a specific point could be selected as the hot-point, we'd be better able to control compositions in-camera. Write to Pentax-Ricoh, tell them you want selectable CIF points! That should take only a minor firmware rewrite. Until then, shoot with the subject centered, and compose in PP, ie, crop it.
12-27-2011, 12:05 PM   #21
eddie1960's Avatar
That would be so useful when shooting fast lenses wide open
01-03-2012, 03:24 AM   #22
Yes I know there a ways to deal with the issue but if i'm using a 50mm lens, that's not to crop the picture in post processing...
camera, dslr, k200d, lens, photography
K200D PDF Manual? JETninja Pentax DSLR Discussion 2 02-05-2010 02:23 PM
Is there a 1/5 sec limitation with manual lens on K200D? cbaytan Pentax DSLR Discussion 13 12-28-2009 09:32 PM
K200D: Problem with manual focus tele_pathic Pentax DSLR Discussion 3 11-08-2009 10:05 PM
Manual Focus with the K200D atyab Pentax DSLR Discussion 8 12-30-2008 02:12 PM
All times are GMT -7. The time now is 05:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
