12-13-2011, 08:20 AM   #16
telly0050's Avatar
now i only wish there's another dslr that has even similar dimension with the kx.
but can't complain about that~
12-14-2011, 08:38 PM   #17
QuoteOriginally posted by tigerzen Quote
1 Get a grip for a Canon xt usually around twenty dollars on EBay...
there are many I chose the SAKAR grip because it was the cheapest at 17 dollars. It feels as cheap as it is but it works good for me. Other grips are better made but cost more.
The canon xt is almost the same size as the kx but only slight difference and the grip will protrude a bit on one side but the SCREW will align fine with the camera's tripod mount. I also use this grip for my Pentax ist DS.
2 Remove all the screws that hold the metal plate and remove plate
3 Remove a small pin. This is a small pin that stabilizes the Canon to the grip...Pentax has no hole for this so take it out.
4 Remove the battery stalk by cutting the wires underneath it. The battery stalk should come off easily with the metal plate off. Its held together by a band of wires just snip them off and tuck the wires in the hole.
5 Use a dremmel or hack saw or whatever tools you have to remove a bit of the PLASTIC EDGING to make the grip top surface flush.
6 Put metal plate back on
7 To protect the underside of the camera I used a Neoprene mat that I got at Micheal's for 95 cents. Cut to the size of the grip and then glue. This will protect the camera from scratches also seal the hole where the battery stalk use to be.
8 You will also have to add a piece of Velcro by the camera's battery door and this helps the camera from slipping side to side since we've taken off the stabilization pin that holds this firm to the Canon rebel. I use the small round Velcro dots work great.
9 Use AA batteries in the battery holder to all weight to the grip. I have two dummy batteries and four Enegizer rechargeables that I don't use anymore to add weight. Six was too heavy for me but you can adjust to what you suits you.
STORAGE: The grip can also be used to store extra SD cards and spare set of batteries simply by talking the battery holder out and utilizing the empty space for your stuff.
STABILITY: For me the extra weight really adds stability to the camera and I believe it improves the SR since the extra weight adds some resistance to the small light camera. But the best thing is if you need a small camera just take the grip off. I have also thought about adding lights the grip for Video using LED's.
This is my updated setup
very impressive mod you did there sir, not to mention it looks wickedly good!
02-08-2013, 11:56 AM - 1 Like   #18
Grip for K-X
I have just modified a Canon grip for my K-X. I use 5 AA rechargeables & 1 dummy in the (6) battery tray, which gives me 6.8v with fresh NIMH AA's or 4 Lithium primary batteries & 2x dummy cells - this gives the usual 6-7V with fresh batteries. I made a battery connector from 2x dummy batteries.
I have fitted a small LED voltmeter in the grip which I have connected to the grip switch, so I can see exactly what voltage the camera is getting. The K-X battery problem is no more. I cannot understand why manufacturers don't have a voltmeter in the design as standard instead of the Green - Orange - Red/Off display
I will post pictures, but I am working on powering the grip with the alternative 2x 7.4v lithium rechargeables (I am a bit concerned with the higher voltage, as these batteries can be 8.4v when fully charged.
I did get the inspiration from a member who had used a Canon grip for his K-X.
battery, camera, dslr, grip, hand, kx, lens, photography, screw, weight
Who wants to lose some weight (a weight loss challenge!) jct us101 General Talk 290 05-03-2013 11:49 AM
Macro Just Plain Nasty Rupert Photo Critique 5 09-03-2010 07:55 AM
what is the difference bwt exporting to 8-bit or 16-bit tiffs? rdrum76 Photographic Technique 3 01-22-2009 01:51 PM
Grip, batteries, weight! fishy Pentax Camera and Field Accessories 25 08-03-2008 06:03 PM
K10D Battery Grip : Excellent add on! yeedub Pentax Camera and Field Accessories 9 03-05-2008 02:23 AM
All times are GMT -7. The time now is 09:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
