12-15-2011, 11:31 PM   #1
skid2964's Avatar
Better option for my manual focus lenses?
I have a *istD with a katzeye for use with my manual lenses.
I'm thinking about using a K2000 and getting a katzeye for it.... better? same? worse? to use the K2000 over the *istD for this purpose?
12-15-2011, 11:58 PM   #2
The Sony NEX-5n is the current 'wonder boy' when it comes to ease of use doing MF.
Egronomics and looks aside of course.
Its current selection of good/fast native lenses is poor as well.
12-16-2011, 06:27 AM   #3
Lowell Goudge's Avatar
I guess the first question is what lenses do you have.
if they are KA lenses, then all you give up is the bigger viewfinder of the *istD for an otherwise all round superior camera in terms if resolution, and perhaps high ISO performance, although personally I have always found the 1600 and 3200 ISO performance of the *istD to be quite pleasing.
If you are using older, K mount and M42 lenses, then I believe you really need to think this one over.
From my experience the *istD is about the best, most consistant metering camera out there for legacy lenses, and the *istD supports TTL as well as P-TTL flash, and you can use all legacy lenses with TTL flash.
the *istD can also do something no other pentax can do, and that is to use the built in flash as a slave for high speed sync, with another flash off board. all other cameras can only do this with a shoe mounted flash, not the built in.
In my view, keep the *istD, and since you can get very little for it used any way, buy a second body, if you want better performance overall, but I think a Kr would be better.,
*istd, camera, dslr, k2000, katzeye, photography
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
How Well Does the K-5 Focus With Old Manual Focus Lenses? TomBrooklyn Pentax K-5 14 07-21-2011 05:16 AM
Confirm my understand of metering w/ manual lenses focus hyperfocal focus DeadJohn Pentax SLR Lens Discussion 4 03-25-2011 12:31 PM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
All times are GMT -7. The time now is 06:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
