12-22-2006, 02:54 PM   #1
WMBP's Avatar
shooting with glasses, bright light
I wear glasses. Even after I adjusted the diopter, I still don't feel that I see what's in the viewfinder as well wearing my glasses as without them. And if it's bright and sunny outside, I have an irresistible temptation to put my left had up on the side of my face to block out the light.
Is there a solution for this? I rather feel like I should buy a nun's wimple and throw it over my head while shooting.
Will
12-22-2006, 03:01 PM   #2
-=JoN=-'s Avatar
with or w/o glasses, if it's too bright, I tend to cover w/ my other hand prior to shooting just so I can see everything.
12-22-2006, 03:06 PM   #3
WMBP's Avatar
QuoteOriginally posted by -=JoN=- Quote
Right, but if your left hand is on the side of your face blocking the light, it's NOT under the lens supporting the camera, the way they show the photographers shooting on my Famous Photographers Bubblegum Trading Cards. Not a problem?
Seriously, I'm thinking of taking a black towel with me when I go birding next week, if it's a bright day. I don't mind looking like an idiot in front of the birds.
Or, since I've spent all this money already on the camera, should I just break down and get lasik surgery - or at least switch to contacts?
Will
12-22-2006, 03:10 PM   #4
-=JoN=-'s Avatar
well, I usually just block it out just to see my composition, then I do the usual photographers stance, u know w/ the hand under the lens, etc, etc. adjust settings, and fire. when I do shoot, I mostly have my contacts on, it's easier for me to press my eye against the eye piece, but, I hardly ever find the need to cover up.
ever try those like safari hats or something? a nice towel wouldnt be too bad too I guess
12-22-2006, 03:14 PM   #5
Even with contacts this is still a problem for me in the strong Australian sun.
Using one hand to cover the eyepiece is a technique I sometimes use (this is not ideal). The towel over the head would be a good idea, although you may find yourself in the local lockup
The other method is to get a "rough" reading using the top LED and then use preview to check the histogram.
I have noticed that the contents of the viewfinder become brighter / darker depending on the strength of the light. Unfortunately though, not bright enough.
I have seen a couple of posts showing an attachment to put on the eyepiece and was wondering if that would help.
Regards
Bob
12-22-2006, 03:26 PM   #6
WMBP's Avatar
QuoteOriginally posted by K10D Quote
Nah, I'll be shooting up in Arkansas. No one will notice.
WP
12-22-2006, 03:46 PM   #7
clarenceclose's Avatar
When I used to wear glasses I came up with a different solution.
First when in the sun, wear a white booney had that is black under the rim.
Second, you must have an old pair of glasses around where the perscription is close to what you wear now. Determine where on the lense works best for your viewing purposes and have your optometrist grind down the edge of the lense to the size you need. Attach it over your viewfinder. On my 35mm I used fishtank clear silicone sealant as it was a simple viewfinder. On the newer cameras you may have to devise something else so as not to goop up any moving or disolveable parts.
Now it is your camera for your eye only and you don't have to worry about contacts and dust blowing in your eye.
And for heaven's sake don't get that surgery. I got rid of my glasses using simple eye exercises. Left eye was 20/400 now is 20/40. Takes some effort but it is worth doing and I don't have those darn dents in my nose anymore.
12-22-2006, 04:54 PM   #8
bdavis's Avatar
That is possibly the most intense solution I've ever seen, Clarence.
I've got glasses...&a baseball cap to block out the sun. (Currently rockin' a "I saw Sue at the Field Museum" cap/or a black 'X-box' cap) You've got to tilt it back a bit sometimes, but it works.
12-22-2006, 05:44 PM   #9
QuoteOriginally posted by bdavis Quote
I arrived at this solution because I kept either scratching the lense on my glasses with the camera back and/or shoving my glasses back toward my eye so I could take advantage of a wider field of view through the viewfinder.
I like booney hat style as it is floppy and even if slightly tipped back can flex on the side toward the light to block the glare.
12-22-2006, 05:48 PM   #10
foxglove's Avatar
Same problem, whether I'm wearing glasses or contacts - it's just not possible to see the viewfinder info properly in bright light, sometimes it's even difficult to focus. If I'm wearing my hat, I'm sort of okay. If anyone knows of a big rubbery eyepiece I'd like to hear about it! I'm sure I've seen them before...
Julie
12-22-2006, 06:10 PM   #11
Something like this?
eBay: Eye Cup Eyecup for Pentax LX & K 1000 Camera NEW $2SHIP (item 120067304553 end time Dec-28-06 05:58:38 PST)
12-22-2006, 06:15 PM   #12
bdavis's Avatar
Clarence, if it works for you, it works. I'm not knocking it, but it's not something I would have ever considered. Like I said, it's too intense, so I'll just have to suffer my own solution. And with as much sun as we get in NM, I'll be suffering quite a bit.
12-22-2006, 06:22 PM   #13
slip's Avatar
QuoteOriginally posted by WMBP Quote
Will
would prescription sunglasses work?
or possibly do what clarence says with the ground down eye glass in the view finder and put on sunglasses as well?
I hope I got the question right
randy
12-22-2006, 06:26 PM   #14
slip's Avatar
QuoteOriginally posted by clarenceclose Quote
could you please let me know more about this?
my eyes are right off the chart when it comes to reading without glasses.
thank you very much!
cheers
randy
12-22-2006, 06:39 PM   #15
bdavis's Avatar
Not to keep picking on you, but you've actually scratched your glasses with your camera? I've got an illustrious history of stopping things with my face, all coming with enough force to tell me that I should probably avoid such situations, but I've never scratched my glasses. Shattered the frame of some unbreakable sports goggles, and I wonder at the state of my nose sometimes, but no scratches. None. I'm finding it hard to believe that I could cause such damage with my viewfinder.
camera, dslr, glasses, light, photography
Nikon D3 - How do I turn off that bright light during auto-focus? Noob Non-Pentax Cameras: Canon, Nikon, etc. 8 04-22-2011 06:00 PM
Architecture Stairs (bright light mood) bombel Post Your Photos! 8 03-27-2011 04:05 AM
Can you see a TLR finder in bright light? sewebster Photographic Technique 6 02-15-2011 07:47 PM
Horribly overexposed images K10 in bright natural light geek-girl Troubleshooting and Beginner Help 16 01-07-2011 01:57 PM
Shooting Video In Bright Sunlight ggray Video and Pentax HDSLRs 10 08-05-2010 09:57 PM
All times are GMT -7. The time now is 06:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
