12-25-2007, 06:09 PM   #1
Pentax K100 Dark Image
I have a K100 and it does not seen to matter what lens is connected to the camera. I can be using the camera for many shots and it seems to be working just fine and then it will stop working and will shoot a very, very dark image. I will not have moved or changed anything. A trick that seems to work to fix it, is to take the lens off, shoot a picture with no lens and replace the lens. This process often enables the camera to work again for a few shots. However it will stop working again soon. I have tried to find some pattern in this process and have not found one. The camera is making a much louder static noise then it have in the past...
12-25-2007, 07:04 PM   #2
Welcome to Pentax Forums Camper.
Sorry that I can't really help you, however I'm wondering if it's somehow memory card related
If you have a second card I'd install it next time and see if your problem goes away.
And if you don't have a spare it's a good investment, just in case something happens to your old one.
If a memory card doesn't solve your problems I hope that it's under warranty. I'd take it back to the store you got it from if it is.
12-25-2007, 07:28 PM   #3
Good Thinking! I did not think of that however, I tried a new memory card and it still did the same thing. I am concerned to take it in.. It have been just a year since purchase so I do not believe it will be covered and it is so inconsistant that I do not know when the problem will show or how often. I just shot off 10 shots. 1) Great, 2) Great, 3) Dark, 4) Dark, 5) Great, 6)Great, 7) Great, 8)Great, 9) Dark, 10) Great... I did not change anything these were 10 Rapid Fire
12-25-2007, 08:07 PM   #4
Moderator Emeritus
I thought Stu's idea might be it. You might want to clean the lens contacts on the lens and camera mount. The Static noise is also a concern. What lens are you using?
12-25-2007, 09:11 PM   #5
Canada_Rockies's Avatar
QuoteOriginally posted by Camper0414 Quote
Do you have another lens to try? The "static noise" might be a failing mechanical connection in the lens aperture mechanicals. If not, see if you can replicate the problem either with the lens wide open or at minimum aperture.
12-26-2007, 12:53 PM   #6
LeoTaylor's Avatar
The Original Post says it happens no matter what lens is attached and it does not sound like a battery problem.
So it must be camera related. One thing worth trying is resetting the camera in case it is in a funny mode and confused. On my K100D there are two resets, at the end of the Setup menu and the Custom menu. A long shot, but takes only a moment to try. I've "fixed" a few of my sister's Fuji's that way.
12-26-2007, 02:01 PM   #7
Duck Dodgers's Avatar
Another Pentax forum had a similar thread recently, or it might not be related at all. The spring that activates the aperture lever had slipped past its retainer. Apparently, this also resulted in the "on-off collar" feeling "odd" when he tried to activate the DOF preview. Can't find the thread right now, though...
camera, dslr, image, k100, lens, pentax k100, photography, process, shots
For Sale - Sold: Pentax K100 and 3 lenses! jboyde Sold Items 8 12-11-2009 08:00 AM
Pentax K100 Super flash question pentaxable Troubleshooting and Beginner Help 5 11-23-2009 02:09 PM
fish-eye lens for pentax k100 pcnw Troubleshooting and Beginner Help 3 10-16-2009 11:37 AM
All times are GMT -7. The time now is 01:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
