Originally posted by Anvh Try live view, it should roughly give the same metering although it works differently.
It works as described. 1/2 stop compensation and I hit the middle of the histogram, but I had to be in AV mode. The histogram didn't change according to the shutter speed changes in manual mode.
Then tried manual again and same results as before. Worst cases (few of them) deviated by 1 1/2 stop.
Then tried manual but using with center weighted metering and nailed it every single time without any compensation. But I was aiming at flat bright surfaces so this conclusion, or finding rather, may prove not to be as exact in real work scenarios.
Marc: I find this subject to be very interesting. I used to dial in based on what I saw in LV, and only little based on the histogram. An shot can be very underexposed but still look OK if only looking at the LV.
I recently purchased a DVD were there's a talk about metering and how to learn to recognize various shades (in colors especially) and thereby be able to pre-dial more precisely without having to do as many test shots.
Before this I wouldn't "uh, white surface. Meter it and open up by 2 stops". This gets me in the ballpark and ultimately I'm aiming for what you do, but I only just recently started to *really* pay attention to the histogram.
