12-26-2007, 12:54 PM   #1
NYpHoToGraphEr's Avatar
Brother messes wiht my camera= Shutter lag problem
Hey,
Yesterday my brother asked me for my camera batteries so he can use
them for the Wii I said yes later I found out he also took pictures the problem
now is that my camera has a serious problem with shutter lag and only if
I press the button to the sides and stuff does it take a picture.
Any help is appreciated.
12-26-2007, 12:57 PM   #2
ericc's Avatar
Did he turn on the 2-sec mirror up? Go to the Fn Key and press the 4-way controller up to reset to normal shooting.
12-26-2007, 01:00 PM   #3
nope that is not the problem.
sometimes it doesn't even shoot.
i have to press it like 5 times.
he used it for a party his friends were having in my room
and his maybe a spill i know he wont tell me.
12-26-2007, 01:21 PM   #4
Moderator Emeritus
I figured Ericc had the correct answer. You've gone into the menus and reset the camera? If so and the probem still persists. Then take out the battery and leave the camera over night. Any liquid could be causing an electrical short and wuld further damage the camera. In the morning put the battery in and try it once or twice to see if the camera works. If not remove the batteries and get it off to service. You should also have a close look at the battery compartment before you do anything more and see that it's dry and that the batteries are dry as well.
Any visible signs that it was dropped?
12-26-2007, 01:28 PM   #5
QuoteOriginally posted by Peter Zack Quote
Ok so you want me to go into my menu and find something that says reset my camera,
I can do that. The batteries werent in the whole night already and if it was a electrical problem
like a spill I think it wouldnt turn on. I dont think it was dropped no scratches then again theres carpet in my room.
12-26-2007, 01:35 PM   #6
Hey,
it seems to be working now after that I followed your helps and formatted my camera which i dont even know what that does. I did take out my memory card before i did it just in case.
now it works pretty much but i forget, how hard do you have to press your shutter for it to take a picture.
12-26-2007, 01:43 PM   #7
It sets the camera back to its defaults. Some times things get bit wonky in these things, and a reset *usually* does the trick.
Not always but a cheap starting point.
Dave
12-26-2007, 01:52 PM   #8
Moderator Emeritus
QuoteOriginally posted by NYpHoToGraphEr Quote
Hey,
Cool, As the above post says. These electronics can have "off" days and do weird things. As for shutter press, it's fairly light for focus (half press) and then about double for the shutter release. Hard to describe with a post though.
12-27-2007, 06:32 PM   #9
LeoTaylor's Avatar
QuoteOriginally posted by ericc Quote
My K1x0Ds forget 2 second delay after being power cycled, so that is not likely to be the problem. As someone who uses the 2 second mirror up delay a LOT it is a bit annoying for a camera that remembers almost all other settings.
Oddly, another Fn setting, Continuous, is retained after a power cycle.
I'm glad a total reset solved the problem.
12-28-2007, 07:32 AM   #10
Lowell Goudge's Avatar
it almost sounds as if the camera was set to AF Sincle mode, where the shutter is interlocked with focus confirmation. check the front switch.
12-29-2007, 01:59 AM   #11
Mike Cash's Avatar
My first thought was to recommend laying a beating on him just out of general principles, but lacking any direct evidence of irresponsible mishandling of the camera it is sort of hard to justify that.
My second thought is to make him a present of a recharger and a set of Eneloops so you can justify never again loaning him your stuff and still look magnanimous. Maybe give him one of those disposable cameras too.
brother, camera, dslr, photography, shutter
K20D Shutter Lag nanhi Pentax DSLR Discussion 3 08-09-2010 04:20 AM
K20D slow shutter lag RollsUp Pentax DSLR Discussion 9 10-26-2009 04:54 AM
inexpensive and no shutter lag? DanLoc78 Pentax Compact Cameras 8 10-14-2008 04:34 PM
HELP: Camera Shutter Lag DJey Pentax DSLR Discussion 9 08-22-2008 06:42 PM
Shutter lag debate K10D Christian Pentax DSLR Discussion 49 04-21-2007 05:26 PM
All times are GMT -7. The time now is 10:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
