01-06-2012, 08:54 AM   #1
hman's Avatar
K-x question
Just upgraded from K100D to K-x, and have a question. I am shooting RAW (DNG) and editing in LR3. With K100D, image uploads to forums were always accepted as the file size was OK. I was unable to upload today and realized that the jpeg image file was 8000kb. As usual, I exported the file to my hard drive from LR as I was used to doing, anticipating uploading it to forum. I know there's a setting issue, but so far, the manual has not been helpful. or I'm dense. Can you help?? Thanks in advance.
01-06-2012, 09:03 AM   #2
sterretje's Avatar
I don't use LR, but that is basically where you must look. You have to resize and (optionally) change the quality level of the exported jpeg.
01-06-2012, 09:27 AM   #3
hman's Avatar
OK. Re-exported from LR to hard drive with max size 700kb and max dimensions 1024x700 specified (actual size now is 687kb and 1024x680) and still timed out with this error message that I've never seen before:
Your browser sent a request that this server could not understand.
Thiughts?? Thx
01-06-2012, 09:46 AM   #4
Emperor and Senpai
VoiceOfReason's Avatar
I use a batch resizer and normally resize to no more than 800x600 and generally get an output file size of 250 or so kb.
The error may be with the site or with your browser, and that's where I woudl look before looking at the pics you're uploading. I am sure there is somethign here showing max file sized though.
01-06-2012, 09:51 AM   #5
hman's Avatar
The site states images must be 700kb or <, and no > than 1024x700. Browser seems to be working, but I'll close and re-start, and re-size the image. Won't hurt anything; no indication that it's the site. Thanks
01-06-2012, 10:05 AM   #6
QuoteOriginally posted by hman Quote
Thiughts?? Thx
Slight possibility -
did you name the new photo-file with the same filename as previously?
If so there is a slight possibility that the previous (larger) version was cached
and the upload "saw" that instead of your newly saved (smaller) version?
01-06-2012, 10:06 AM   #7
hman's Avatar
All is well. Resized to VoiceOfReason's suggested values. Thanks so much!!
01-06-2012, 10:08 AM   #8
jatrax's Avatar
My LR3 export settings for this forum are:
jpeg; sRGB; quality 80
resize to fit: long edge = 1024; resolution = 240
sharpen for screen; standard
That seems to work for me, although I have not tried it fr a couple of weeks.
01-06-2012, 10:25 AM   #9
hman's Avatar
Thanks so much- I'll create an export setting that is similar.
camera, dslr, file, image, k-x, k100d, photography, question
First question cjbroadwell Troubleshooting and Beginner Help 8 01-05-2011 02:23 PM
Kx question. Unr3a1 Troubleshooting and Beginner Help 5 08-30-2010 09:06 AM
I have a question? Kimbolina Troubleshooting and Beginner Help 18 07-21-2010 06:06 PM
K-x AF Question benjikan Pentax DSLR Discussion 16 04-07-2010 10:41 PM
Sigma 10-20 question dehanson1 Pentax SLR Lens Discussion 14 01-22-2010 09:43 PM
All times are GMT -7. The time now is 09:13 PM. | See also: NikonForums.com, part of our network of photo forums!
