Originally posted by jsherman999 .
The use of your phrase 'Greater perspective' here indeed tells me that you've been working on a different concept than what we were originally trying to describe. (FWIW, I wouldn't call that 'greater perspective', I'd call it 'greater convergence'.)
I am sorry. I thought the argument was effect of cropping an image in regards to perspective--say, using a full-frame senor vs. a APC sensor with the same lens would not impact perspective.
The example I provided clearly shows Linear Perspective. It also shows the perspective is changing because of cropping or a change in focal length while maintaining the same object distance. And the more you crop, the less perspective the image will have until you you reach an infinitely small area where the image will have no perspective at all--or in common usage, space is being compressed. This is really basic stuff.
I am not really interested in your personal nomenclature. For your reference, here is the common definition of perspective from a standard source,
The Focal Encyclopedia of Photography, Third Edition, page 548-55:
Quote: PERSPECTIVE Perspective refers to the appearance of depth when a three-dimensional object or scene is represented in a two-dimensional image, such as a photograph, or when the subject is viewed directly.
The article, as you can see, is quite long and thorough and never is you concept of "Convergence" mentioned. As far as perspective having no degree, you have hundreds of years of perspective drawing to contradict that. And before you claim that it has nothing to do with photography, the concepts on linear perspective in photography come directly from this work. The topic in photography has taken this work and expanded it to cover the problems that are unique to the medium.
The fact is, object distance is not the only factor in changing perspective in an image. I have provided the proof and explanation. Playing vocabulary games will not change that.
