01-12-2012, 10:47 AM   #1
Possible problem with manual lens on KR
Hey,
When I use my manual lens in my kr and put it on 'm' mode then put it to say, f8, and then do the stop-down metering thing, the image through the viewfinder becomes blurry, depite the fact that I have just focused the lens. When I press the shutter release, the mirror jumps up again and it is no longer blurry through the viewfinder. Also, sometimes rather than making a single clank, the shutter makes a double clank, as if I was firing in live view... Is this normal? Feedbcak appreciated.
Charles
01-12-2012, 11:16 AM   #2
Hi, Charles... I get the same behavior with my M50 and K-r! It only happens occasionally, though. You might try re-seating the lens to ensure tight contacts. Otherwise, I'd love to hear the resolution to this.
01-12-2012, 11:33 AM   #3
QuoteOriginally posted by ofer4 Quote
I get it with my M50 f1.7 and chinon 28mm f2.8 (manual also)
01-12-2012, 12:09 PM   #4
Sounds like a bug in the camera- hopefully a firmware fix is being worked on!
01-12-2012, 01:17 PM   #5
Philoslothical's Avatar
Bare metal lens mount, or painted/anodized black? I had a similar issue with a particular lens, and solved it by insulating the contacts from the lens. However, to use CIF, or some other features, you would have to allow shorting of the data contact, at least (if you don't use CIF, don't worry about it).
01-12-2012, 01:23 PM   #6
QuoteOriginally posted by Philoslothical Quote
Cheers-what CIF?
01-12-2012, 04:40 PM   #7
CIF means "Catch in Focus". It's when you set up the camera to fire automatically when something enters the focused area of the scene. I haven't found much use for it yet, but some people like it.
01-15-2012, 10:00 AM   #8
Huh?
This is the way I read this:
  • Manual focus lens
  • Becomes blurry after stopdown
  • resolves after shutter cycle
A few things to consider:
  • AF system is ruled out and that includes catch-in-focus (lens focus is not coupled to body)
  • Mirror is ruled out (does not move during stop-down)
Normally, I would suspect that there is a mechanical issue with the lens that shows itself when the aperture is actuated. Having the problem with two lenses rules that out. Are you sure this does not happen with your AF lenses as well?
01-15-2012, 10:54 AM   #9
Huh?
  • Manual focus lens
it happens with the chinon-when u stop down ur manuals, does the image in the viewfinder shift at all?
01-17-2012, 04:34 PM   #10
screwdriver222's Avatar
Hi Chaz.
I have had occasional problems with the manual lens I use. The image in the viewfinder didn't go blurry but dimmer. I am pretty sure this is the aperture blades sticking.
04-11-2012, 01:32 AM   #11
Have the same problem with my 6-weeks-old K-r (with two lenses, Ricoh 50/1.7, Ricoh 28/2.8). I investigated a bit and I think that:
1. The blurry view is because the mirror doesn't fall properly, it stops 2-3mm above the down position
2. Some people says its a power problem, using the normal AA batteries should solve it (havent try yet)
3. It happens in some particular circumstances - NOT fully charged battery and probably have some temperature dependence too... Happend much more often when it was colder (like 10-15C) but this one I'm not sure..
I'm sending my camera to the service and see what they say..
04-11-2012, 12:58 PM   #12
I've had my KR for about 2 months, and noticed this for the first time last weekend with my M50 1.4. Image in view finder slips out of focus immediately after stopping down. Remedied by tripping the shutter, which caused an unusual double click, like the sound of taking a picture in LV. To me it seemed to be something to do with the position of the mirror. It seemed to stop doing it after I changed the switch on the camera from AF to MF, but this may be coincidence. My battery was getting a bit low, and it was a bit chilly at the time. Renegat - Would be interested to know what the service people say to you.
04-11-2012, 01:01 PM   #13
Now I had to postpone the service, becuse I'm going for a trip and they told me they wont manage to finish it within 2 weeks Anyway.. I'm going to buy the battery pack and see if using the AA batteries will help. I'll update when I know something.
04-11-2012, 03:41 PM   #14
QuoteOriginally posted by owatkinson Quote
That's exactly the problem I have EXACTLY but with my M50 1.7!
04-12-2012, 12:30 AM   #15
Chaza, have you found any solution?
camera, dslr, kr, lens, photography, shutter, viewfinder
KX with 28mm manual lens problem bjake Troubleshooting and Beginner Help 2 12-15-2011 12:06 PM
Quite strange problem when I'm using manual lens kenl Pentax K-r 9 09-08-2011 05:35 PM
problem with K-X and K mount manual lens shinjitsu Troubleshooting and Beginner Help 10 05-12-2011 11:34 AM
pentax k-7 SR problem with manual focus lens lwsy711 Troubleshooting and Beginner Help 4 07-17-2010 04:02 PM
Weird Manual lens problem columbus Pentax SLR Lens Discussion 11 09-27-2009 02:00 PM
All times are GMT -7. The time now is 03:42 PM. | See also: NikonForums.com, part of our network of photo forums!
