12-28-2007, 05:14 PM   #1
Cleaning my K10D, Dead Pixels on LCD
So, I've been noticing little specs of dust inside my K10D. I already checked the mirror and the sensor, and it's not on either of those. I have a pretty good feeling it's behind the focus screen. What can I use to clean the focus screen and the screen behind it leading to the viewfinder? I don't want to use any sort of fabric that leaves off hairs and strands cause then if I clean the dust, there will be more to clean and it'll never end.
EDIT: Lcd dead pixels issue, last post.
12-28-2007, 07:59 PM   #2
joele's Avatar
Be VERY careful with the focus screen, they are a type of plastic and scratch extremely easily.. better not to wipe it with anything. Use a blower bulb that you have checked doesn't have any gunk in it (use it on your skin first). You can blow up onto the bottom of the the screen, if that doesn't work their is a little catch at the top front inside the camera that lets you get to the focus screen. Open that carefully and use the blower again on the other side of the screen.
12-28-2007, 08:05 PM   #3
It's not on the focus screen. I checked it already. It's actually on the surface behind the focus screen. I don't know how it could have gotten there, but that's where it is. There's actually some lint in there too. I have no clue how it got there.
12-29-2007, 12:14 AM   #4
joele's Avatar
So do you mean closer to the actual eyepiece (in between that eyepiece and the focus screen itself)?
12-29-2007, 02:40 PM   #5
Yes, that's what I mean. I have no clue how the dust got there, but it's annoying me way too much.
12-29-2007, 04:08 PM   #6
LaRee's Avatar
join the many
QuoteOriginally posted by tux08902 Quote
Actually I think this is quite common on the k10d. I also have fibers right where you describe and they are harder to get rid of than sticky dust on the sensor. I haven't fooled around with mine, after hearing of some folks ruining the focusing screen trying to clean behind it. I haven't found that the blower moves anything in this particular area. It is the pits and it was annoying as heck for me too. I've since come to ignore it. At least it doesn't affect my photos. I've cleaned my sensor a couple times with good results, but this area in the viewfinder is the pits!
12-29-2007, 04:42 PM   #7
Canada_Rockies's Avatar
QuoteOriginally posted by LaRee Quote
I have only one small bit of gunk on mine, and I have no intention to even attempt to remove it. All my other SLRs have bits of gunk up where no one can get at it. They are very annoying, but don't affect the picture.
12-29-2007, 04:49 PM   #8
distudio's Avatar
It sounds like the contaminants are on the condensing lens above the focus screen. The easiest way to clean it is to remove the focus screen and blow it, you may even have to loosen the dust it with a brush (it's pretty robust, the screen is the sensitive bit). You'll probably have to go through a sensor clean routine after too.
12-29-2007, 05:00 PM   #9
I'll giv eit a shot, but hearing your stories, I guess I'll have to live with it. I noticed something else today. My K10D has two dead pixels on the LCD. Those pixels are always black. That's what prompted me to clean the camera. Then, when I noticed they didn't go away, I tried zooming in and they didn't get any larger. So, has anybody experienced this. Will Pentax replace the body? I know it's not that big of a deal and that all electronics have a certain degree of defects even when they pass. So...I don't know what to do. Other than these two things, I love my camera!
12-29-2007, 06:05 PM   #10
So, I did some cleaning, and I got rid of the big stuff, but there are small dust particles by the corners. I guess I'll just have to live with it.
What can I do about the dead pixels on the LCD? It's not that big of a deal, but does Pentax even replace the body for that.
12-29-2007, 07:32 PM   #11
joele's Avatar
They don't replace the body, you can get them to 'map' out the dead pixels. I had it done for my old DS, it had enough that they didn't charge me (I am not sure the exact amount to get it done for free)..
12-30-2007, 09:39 AM   #12
Jodokast96's Avatar
I thought your dead pixels that they mapped were on the sensor. His are on the back LCD.
12-30-2007, 05:41 PM   #13
My dead pixels are on my LCD. There are just two of them.
camera, dslr, dust, focus, k10d, photography, screen
sensor cleaning for k10d chicochongchu Pentax DSLR Discussion 16 02-03-2009 11:35 PM
K10D Cleaning EAD Studios Pentax DSLR Discussion 2 08-26-2008 06:57 AM
Cleaning Of Focusing Screen on K10D Mapleleaf-Mick Pentax DSLR Discussion 1 02-10-2008 05:51 AM
Automatic Sensor Cleaning in k100d Super and k10d superfuzzy Pentax DSLR Discussion 3 11-19-2007 04:18 PM
Cleaning K10D Sensor with Eclipse pentaxbling Pentax DSLR Discussion 2 09-05-2007 01:39 AM
All times are GMT -7. The time now is 11:02 PM. | See also: NikonForums.com, part of our network of photo forums!
